Strange Ticking - Defender Source
Old March 27th, 2009, 09:50 AM
wadaman
Glenn Wada
97 D-90 #1257
Strange Ticking
So it happened again this AM. As I was driving, I started to hear a strange ticking that sounded just like a turn signal or emergency flasher ticking. But neither set of lights were in use.
I had just turned off my intermittent wipers. Could this be the culprit? This is the second time it's happened in two months. Cured if I turn off the ignition and restart the truck.
Anyone have similar issues / help diagnose?
GW
Old March 27th, 2009, 10:52 AM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Mine has done that. It just goes away on its own. It is a stuck relay or something.
Old March 27th, 2009, 03:39 PM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
I did a search and found this after I had the same thing a few weeks back. there are several threads about this.
also thanks for the belts they are in great condition, so much better than mine were.
If it is coming from the dashboard area it could be the following.....has something to do with the anti-theft device.
Clicking in 10AS Control Unit
AFFECTED VEHICLE RANGE:
DEFENDER (LD) VA992105 to VA999484
VA100300 to VA126471
SITUATION:
INTERMITTENT CLICKING NOISE FROM DASHBOARD
An intermittent clicking noise may be heard coming from the dashboard on some '97 model year Defenders. The clicking noise sounds very similar to a turn signal flasher in frequency and loudness. Once the clicking noise begins, it will continue until the ignition switch is cycled off and then on again. The source of the clicking noise is a relay within the immobilization control unit (10AS unit). A revised unit is now available to address this symptom.
RESOLUTION:
REPLACE IMMOBILIZATION UNIT
To address a customer complaint matching the above description, verify that the source of the clicking noise is the alarm ECU and replace the unit with the latest type.
PARTS INFORMATION:
AMR6430A Immobilization Unit
strange happenings joeoftherock Defender Technical Discussions 8 May 9th, 2005 11:31 PM
Ticking noise at idle thug1313 Defender Technical Discussions 11 March 10th, 2005 11:20 AM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
Strange feeling while driving... wicks Misc. Chit-Chat 5 March 3rd, 2005 01:37 PM
strange 9/11 video jperakis Misc. Chit-Chat 2 January 17th, 2005 07:35 PM
