Strange Sound - Defender Source
Old March 21st, 2006, 06:01 PM
tron's Avatar
tron
Thomas F
Recently Roverless
Strange Sound
So on the front driver's side (US Side) I have had an annoying sort of chiming sound when I drive over any rough road. I would compare it to a loose key dangling on a key chain hitting another key (a bit out there I know). Anyway, I can reproduce it a little when I jostle the car by hand (even when the engine is not running). My guess is that it might be time for some new shocks but I just wanted to see if anyone else has heard anything similar. I know it is a bit vague but I just wanted to see.
Tom
Old March 21st, 2006, 07:11 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I know what it is--you are not going to believe it at first since it does not sound like this is it, but I would bet on it. It is the hood hinge at the black plastic thing. What I did to correct it is take a piece of wood and a mallet and smack the hinge to close the gap (the part that is attached to the bulkhead that looks like an open loop). Problem solved.
I opened up my dash looking for it before I figured it out. Took me about a month.
Old March 22nd, 2006, 10:12 AM
tron's Avatar
tron
Thomas F
Recently Roverless
So the black plastic thing would be the half moon piece that sits between the metal hinges correct? Or is this something else?
Tom
Old April 4th, 2006, 01:42 PM
tron's Avatar
tron
Thomas F
Recently Roverless
Did not seem to do the trick...any other ideas? Sounds like it is lower down closer to the wheel.
Old April 17th, 2006, 03:03 PM
tron's Avatar
tron
Thomas F
Recently Roverless
I finally had 10 minutes of free time to poke around a little and it looks like it is the bearing on the shock. It has been time to replace them for way too long so now I have a good excuse to get started.
Old April 17th, 2006, 03:09 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Try a little oil [light] on the bushing for the shock.
Old May 6th, 2006, 06:12 PM
tron's Avatar
tron
Thomas F
Recently Roverless
I finally replaced the shocks a few hours ago with my British co-hort and this killed a few birds.
First, I got rid of the sound of the washers clinking together since the bung was looking like chewing gum...pretty much gone. The front shocks looked like they had been leaking which broke down the rubber and made the sound.
Second, I was among the many here who had the death wobble around 50 MPH. I had an assumption that the lack of shock bushing might have had something to do with it. Sure enough it is straight as an arrow now that the new bungs are in. Plus, with the Blisteins use gas so the hydraulic fluid leak will no longer be a problem.
I must say that the upper cone piece for the front shocks is designed pretty poorly for us folks who don't have shock compressors. The lip sits under the edge of the metal wheel wall making it impossible to get out if you don't compress the spring. But a trusty crow bar did the trick for us.
Quote of the day from the Englishman was "This does not look right...it's English, it might be metric."
does this sound like a rover V8 rover4x4 Misc. Chit-Chat 4 January 5th, 2006 06:24 PM
Sound Dampening Material kellymoe Misc. Chit-Chat 1 March 13th, 2005 01:34 PM
Fuel Pump Sound ronward Defender Technical Discussions 4 January 10th, 2005 07:45 AM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
Weird sound at idle... OCD90 Defender Technical Discussions 1 November 10th, 2003 02:56 PM
