Strange noise from driver side front tire/axle? - Defender Source
Old August 11th, 2012, 10:45 PM
jkins
john
95 Defender 90 - Beluga
Hello all,
I have a 94 D90 with about 85000 miles on it. Just today I started hearing a weird noise from the driver side front tire/axle... It is kind of a grinding but everything ran fine. I thought it was initially the brakes but it stopped after a bit.
Then it restarted... Then quit again.
Any ideas without more evaluation?
Old August 11th, 2012, 11:30 PM
Stone trapped in brake caliper
Old August 11th, 2012, 11:44 PM
jkins
john
thanks for the replies guys.
is this something i can fix or does it need a trip to the shop?
Old August 12th, 2012, 08:48 AM
Bearings are very easy
Old August 12th, 2012, 07:51 PM
jkins
john
any guidance online on how to check this out?
thanks guys!
Old August 12th, 2012, 08:22 PM
They are cheap and it's a reasonably good chance they are at fault. If you don't know when they were last done you might as well change them!
axle, tire
LT230 front output shaft noise dsh12 Defender Technical Discussions 13 April 2nd, 2011 04:26 PM
90 / 110 Front Wing Side Panels Wolf Fabrication Wanted 7 December 31st, 2009 05:47 PM
Front seats, side mirrors, steel lugs Method PHX Wanted 1 November 19th, 2005 07:41 PM
Wanted: D-90 seat back trim cover/ driver's side side step dzientek Wanted 2 August 23rd, 2004 06:39 PM
Need 10 Spline Pass. Side Front Axel... h2eater Wanted 3 August 14th, 2004 09:57 PM
