strange distributor idea - Defender Source
Old December 7th, 2009, 06:11 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Has anyone tried running a small air line to the distributor and turning on enough psi to it right before crossing deep water. Maybe making use of the ARB compressor? Just trying to think of alternative ways to get it to live with water without completely sealing it. It has to breath right? Or is sealing it and running a breather out of it to a snorkel good enough?
Thanks.
And hay
And I love you too
Old December 7th, 2009, 07:48 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I was about to dismiss the idea totally.... but I have to say it's got some interesting possibilities now that I thought about it.
Not sure if it seals enough for an overpressure type of concept to work in this application, but I have to say that the IDEA is a valid one. It all depends on how much ventilation it has, how much air volume and pressure you put into it, and if you can force water out of it in that situation.
My only real concern is that you probably want some type of good air filter in your supply line, the last thing you want is to be blowing dust into there and causing other issues.
Hmmmmmmm....... intriguing.
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 7th, 2009, 08:23 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Maybe I could try testing one out of a car by trying different psi from the shop compressor and submerging in a 5 gallon bucket to check the theory. I thought if it would work and their is already air available, add another relay and switch.
And hay
And I love you too
Old December 7th, 2009, 10:02 PM
Keep in mind it usually has a rotor spinning at thousands of rpm which it won't have in the bucket test. I assume this will affect the pressure.
Old December 8th, 2009, 11:31 AM
huck1974's Avatar
huck1974
shane cates
94 d90
good thought
And hay
And I love you too
Old December 8th, 2009, 12:00 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I have heard of this before using fish tank air pumps.
Old December 8th, 2009, 01:46 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I've seen this a lot. Usually in comp trucks, the air pressure is regulated down to about 3 psi. Then it is used to keep the water out of dizzy's to ECU containers to front engine covers on diesels.
Keith
Big, Red and ... aaa Red..
Old December 8th, 2009, 03:16 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Thanks. Is there more than one breather hole on our dizzys?
Has there been a consensus on the best way to deal with some amount of water?
It can't be sealed completely because of condensation, correct?
And hay
And I love you too
Old December 8th, 2009, 11:15 PM
cdb
Clark Bowen
Here is RPI's take on what you proposed
http://www.v8engines.com/knowledge/I..._proofing.html
2011 RR HSE -
2001 GMC 2500 4wd
Old December 9th, 2009, 01:49 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
That's a great idea, and a real easy mod!
Old December 9th, 2009, 10:04 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Geeze now I almost want an engine with a distributer so I can try this...
Keith
Old December 9th, 2009, 11:06 AM
huck1974's Avatar
huck1974
shane cates
94 d90
Thats brilliant. Exactly the idea I was looking for. Thanks guys. I will give this a try in the next week or so.
And hay
And I love you too
Old December 9th, 2009, 11:14 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
In thinking about it, vacuum would suck in water if the Dizzy wasn't completely sealed..
I'm back on the pressure bandwagon.
Keith
Old December 9th, 2009, 11:28 AM
huck1974's Avatar
huck1974
shane cates
94 d90
Gotta figure out how to completely seal it. Besides where the cap attaches itsself, how many other areas are we talking about on our ditributors?
And hay
And I love you too
Old December 9th, 2009, 12:47 PM
I'm pretty sure there is a drain hole on the bottom
Old December 9th, 2009, 01:10 PM
pushngo
Randy Williams
I saw a guy at MAR who siliconed his tight. Problemis when it gets hot and water get sprayed on the cap condensation occures on the inside anyways Problem is now you can't get the cap off to dry it.
I think if you are under water long enough to need this enough water will be sprayed on the wires plugs ecu etc that a dead dry dizzy won't help. A good example is all the non dizzy trucks that are dead in the water
Old December 9th, 2009, 02:12 PM
huck1974's Avatar
huck1974
shane cates
94 d90
I agree. I don't want to go swimming with the thing. Just some protection from the "oops, that hole was deeper than I thought" thing. I'm thinking dipping part of the coil in the ruuberized stuff that you dip tool handles in. Dielectric grease and liquid electrical tape for everything else. Going to make a small waterproof box for the ecu and relocate it higher. Just some ideas.
I will take pictures of the dizzy mod when I try it. I'm thinking of getting vacuum by usung a T on the brake booster.
And hay
And I love you too
distributor
Strange things growing in my wife's garden... Trigger Misc. Chit-Chat 9 August 30th, 2005 02:26 AM
Strange... Campbell Defender Technical Discussions 9 June 24th, 2005 10:49 PM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
Strange feeling while driving... wicks Misc. Chit-Chat 5 March 3rd, 2005 01:37 PM
strange 9/11 video jperakis Misc. Chit-Chat 2 January 17th, 2005 07:35 PM
