Stranded in Cape Cod need clutch help! - Page 2 - Defender Source
Old May 31st, 2015, 11:25 AM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
Originally Posted by roverman2010 View Post
But a proper release arm on a V8 is cast iron.
Yip..clutch fork is a cast iron item....why oh why did they ever replace it with mild steel I'll never know?...well..yes,really...to save a few pennies...
(They do at least use a cast iron one one on Td5's)
200tdi Ex British Army 110 Hardtop 139142kms
2.286 Petrol Series 3 Lightweight 75,043kms
3.2DiD Pajero 266,000kms
Yamaha XTZ660Z Ténéré 58112kms
Gas Gas 300EC Ohlins Enduro Moto.
Old May 31st, 2015, 03:08 PM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
Cast iRon? Well... cast steel anyway.
Old May 31st, 2015, 03:12 PM
The TDI ones are not mild steel. They are a very hard steel actually. Just too thin.
Old May 31st, 2015, 03:13 PM
DefenderMd's Avatar
DefenderMd
Ben
Whu-happens... bearing gets sticky and they bend/break?
Old May 31st, 2015, 04:34 PM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
Correct..hard but not too thick lol....the pushrod of the slave cylinder just wears a hole through the dimple in time....you can buy reinforced ones or if a standard one,weld a small steel plate on the back to cover the dimple...so if it does pierce through it'll be rubbing on that instead...
Standard here....
FTC2957 CLUTCH RELEASE FORK | Discovery 1 1989-1998 Clutch | shop | www.lrseries.com
Reinforced here...
FTC2957HD | Heavy Duty Clutch Release Fork
All the best
Old May 31st, 2015, 04:36 PM
DefenderMd's Avatar
DefenderMd
Ben
I've seen that. Pretty standard. grease your push rod and replace with clutch. Would be a strange scenario to push through one in one clutch I'd think.
Then again, the metal GB uses is like 80s japan steel. Some other standard than what we use in the US.
Old May 31st, 2015, 04:48 PM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
Agreed....not a very,very common problem but it does occur. I had 300,000kms odd on my 300tdi and when I changed my clutch(due to a thrust bearing howling like a banshee) my clutch fork was actually OK sort of,if that makes sense. I don't think it would've lasted the clutch if the bearing hadn't have been howling...but,who knows!
In went an AP driveline kit along with a reinforced fork for good measure,for only a few euros more.
Old June 1st, 2015, 09:26 AM
greenmountainrover's Avatar
greenmountainrover
Derek Chace
84 Lightweight FFR
Replaced both master and slave still nothing. Trying the pipe next then on to actual clutch and pressure plate next
Green Mountain Rovers your Defender/Series sales and importation specialist.
802-655-4874
Old June 1st, 2015, 09:30 AM
I feel for you. So frustrating....
Old June 1st, 2015, 09:33 AM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
Derek,
the closest Rover shop is 30 miles north in Plymouth.
David Reimels is an old timer who worked in Sollihull when he was a younger guy (he's in his 70s now), but knows Rovers.
Automotive Repair Shop, Auto Services | Plymouth, MA
they do a lot of General repairs, but David would probably slide you in today's docket if you're in a bind. He's seen all the problems. I wouldn't send quirky late-model Defenders or TDis in his direction, as he is more of a Series guy, but he's worked on my truck before and he's a good guy. He's the guy you want if you need synchros replaced in an LT77 or rebuilt your sals, but not the guy to work through GEMS issues or tune the boost on a TD5.
He doesn't have a shop tow truck, but maybe if you could borrow Ben's trailer and two it up to Dave....
(508) 746-7206
118 Sandwich Street,
Plymouth, MA 02360-2401
------ Follow up post added June 1st, 2015 09:40 AM ------
BTW, When my clutch went last year, I had the same symptoms, but my pedal was spongy with no pressure until 3'4 way down and only partial disengagement of the clutch. You could start it in gear with clutch depressed and the truck would creep forward.
Went about replacing the master and slave just as you did.
Turns out the throughout bearing had bound up and twisted the fork and only one half of the lever was actuating the throwout bearing. Needless to say, the transmission had to come out and throughout bearing replaced. It's a shitty break.
------ Follow up post added June 1st, 2015 09:41 AM ------
http://www.defendersource.com/forum/...ghlight=clutch
Old June 1st, 2015, 09:45 AM
Jackie Treehorn
A
1985 (legitimately)
Where exactly are you in Bourne BTW?
Old June 1st, 2015, 10:19 AM
greenmountainrover
Derek Chace
84 Lightweight FFR
Im back in VT now. I left the 110 with staufferdave6 in Rehoboth. I worked with find till midnight friday then had to go back to the other Rovers as they needed to be operating in the field and had to be back in VT for monday,
Dave tried new master and slave sunday still nothing. He is going to give it another shot early this week. If he cant I will see if he can get it over to Plymouth.
Its been a great 110 so I cant complain at all. All stuff like this really shows how awesome our community is.
802-655-4874
Old June 1st, 2015, 10:36 AM
Jackie Treehorn
A
1985 (legitimately)
Post
I remember getting stuck out in the woods while wheeling years back and countless times being stuck in the middle of nowhere while riding dirtbikes. There is no worse feeling than having to abandon your truck, bike, whatever and go home, or try to find somebody to help. Anyone that's been stranded knows the feeling and how grateful they are to whomever lends a hand, part whatever.
Even if I weren't part of the D-90 community, I'd "pay it forward" any time.
Let me know if I can help arrange anything. I'm stretched pretty thin timewise this week, but if I can help I certainty will.
Actually, if you're in Rehobeth, you may consider Alan Elliot at Cityside garage in Holliston, MA instead of Reimels (if Dave Reimels is busy).
There is another shop in West Bridgewater (even closer to Rehobeth) that routinely works on my buddy's TD5 but I can't recall the name off hand. They are a British car specialist (mostly vintage Jags etc.)
I think the transmission will need to be dropped so it's a bit beyond the capability of a driveway type of repair (sound like it anyway).
Old June 1st, 2015, 11:06 AM
you can slide the trans back enough to do the clutch. Done them in the driveway before though it wouldn't be my preference. It can be done. Good luck!
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 1st, 2015, 11:27 AM
greenmountainrover
Derek Chace
84 Lightweight FFR
We might have had a stroke of luck. It appears the slave for a v8 is bigger then a 4cyl one we used. We are going to try a new v8 slave tomorrow.
802-655-4874
Old June 1st, 2015, 11:33 AM
transientmechanic's Avatar
transientmechanic
1972 SIII
Derek, if you need a hand getting the 110 from Rehoboth back to Charlotte when fixed let me know. I could run it up there for you if schedule permits.
Old June 1st, 2015, 12:04 PM
Better choice than Cityside is BDR in Holliston.
BDR Automotive
1605 Washington Street
Holliston, MA
01746
508-429-4720
Old June 1st, 2015, 12:12 PM
greenmountainrover
Derek Chace
84 Lightweight FFR
Thanks guys. Worst case I can always get it shipped for probably $400. I don't want to inconvenience anyone Main goal is just getting her running again. Hopefully this latest batch of parts from RN will do it.
802-655-4874
Old June 1st, 2015, 12:50 PM
greenmountainrover
Derek Chace
84 Lightweight FFR
Not even close. Lionage turned down a offer from a member of the forum and client of mine to swap his whole lt77 with a spare he had just rebuilt free for him.
------ Follow up post added June 1st, 2015 12:57 PM ------
Also his was locked in gear. My clutch just is not actuating.
802-655-4874
Old June 1st, 2015, 05:45 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Its Deja vu from Linoage's saga.
-Jeff
perhaps it's karma...
Rent my
Great White attacking a Seal pics Cape Cod Rufus Misc. Chit-Chat 31 August 18th, 2015 09:49 PM
VT to Cape Cod ex mod convoy May 29th greenmountainrover Misc. Chit-Chat 34 June 1st, 2015 09:24 AM
RURR - NJ to Cape Cod to NJ Glenn_Guinto Misc. Chit-Chat 0 October 8th, 2014 01:00 PM
A friend of mine is stranded in the Dominican Republic, should I help him? Neil McCauley Misc. Chit-Chat 23 June 20th, 2012 08:31 AM
P-Town Cape Cod Sighting matthewwcarey Misc. Chit-Chat 0 March 24th, 2008 12:10 PM
