Storing a fiberglass top - Defender Source
Old May 5th, 2010, 04:03 PM
rockstardave's Avatar
rockstardave
Dave Dulansey
1995 D-90
Hi,
I'm about to remove mine and was wondering - has anyone stored the roof part vertically?
I will probably suspend from the rafters on a shelf of 2x4s otherwise.
Dave
Old May 5th, 2010, 04:29 PM
Most I've seen have been stored vertically...usually propped against a wall though.
http://www.defendersource.com/forum/...21&postcount=1
Old May 5th, 2010, 04:50 PM
whitelandy33
Pecos
hyundai
When I stored my top I would use 4 of these for each corner. http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
I chose to not store vertically b/c I thought the top was too brittle and it would take up floor space.
I hung the top horizontal above the garage door. It was dead space anyways. Spare bumper was up there also.
Old May 5th, 2010, 05:38 PM
specops1526's Avatar
specops1526
Beluga '97 90
I've had mine vertical for years, makes me worry about it since it's so brittle. haven't even taken a look because I'm worried that there might be damage.
I've always wanted something like this: http://www.eagleday.com/pohastra.html
Ideally a pulley system in your ceiling is probably best.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old May 5th, 2010, 07:18 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Stored mine in many different ways.
Best way was upside down from the rafters. Takes two people to slid it up into the rafters. When it's upside down, outside of top is visible from below, you can store the sides and rear window in it. I put some foam pipe padding on the rafters so I could slide it around easily and not scratch it up too bad.
I've also stored it from the rafters with 4 hooks and two motorcycle tie downs to hold it up there.
The floor against the wall seems to take up too much space I think and you still have to store the sides with glass somewhere. Not to mention it gets hit with things all the time too like that.
Old May 5th, 2010, 07:39 PM
If you have the ceiling space, something like this is the answer
http://www.quadratec.com/products/12020_1000.htm
Add some 2x4s if needed.
Old May 5th, 2010, 07:51 PM
Upsidedown from the rafters with lots of [wide] flat straps.
Old May 5th, 2010, 09:31 PM
mikeybob2@msn.com's Avatar
mikeybob2@msn.com
Michael Sabanovich
1994 Defender 90 #1880
I stored mine vertical, outside, uncovered, in the hot New Mexico sun for 5 years. When I put it back on it was in perfect shape. All I did was clean and wax it. Not one single crack.
That was 9 years ago. I just took it off again a couple weeks ago and still no cracks.
I think it must be about being gentle when removing and installing it even more than how you store it..
1994 D90 #1880
Old May 6th, 2010, 12:50 AM
rockstardave
Dave Dulansey
1995 D-90
Thanks all for the good advice. I am fortunate enough to have a garage with a high ceiling. After I'm done I'll take pics and post!!
Old May 6th, 2010, 04:15 PM
i just sold it and bought a badger II GK
much more weather proof than the FG top.
before i sold it i stored it vertically outside un covered with the sides and rear in the basement.
no issues (it sat on a folded over tarp on the ground.
95' D90 - daily driver..
fiber, fiberglass, fiberglass top, glass
Fiberglass top install question d90_1372 Defender Technical Discussions 7 September 14th, 2009 11:07 PM
FS: NAS Fiberglass Top, NYC area NASD90 For Sale - Parts 1 September 1st, 2004 05:17 PM
Differences between metal and fiberglass top jaherring Defender Technical Discussions 5 June 19th, 2004 05:59 PM
Fiberglass top for Soft Top? boshea For Sale - Parts 1 April 19th, 2004 04:23 PM
Fiberglass Hard Top $1300 cbkearney For Sale - Parts 1 November 3rd, 2003 04:17 PM
