Stop/tail lamp partially working - Defender Source
Old March 8th, 2016, 07:57 PM
zhthomas
Zach
1997 NAS Defender 90 AA Yellow #632
When I turn on my lights, the right rear stop/tail lamp illuminates. However, when I press the break, it does not turn brighter to indicate breaking. The left rear lamp works fine as does the middle break lamp above the rear door. Any suggestions?
I apologize if this redundant. I did a search, and was unable to find a solid answer. Thanks for the help!
Old March 8th, 2016, 08:11 PM
This is what you need. Rarer than hen's teeth now.
Old March 8th, 2016, 08:12 PM
Probably a bad ground at the brake lights.
Old March 8th, 2016, 08:22 PM
zhthomas
Zach
Any recommendations on checking the ground?
Old March 8th, 2016, 08:31 PM
Look at the grounds on the rear lights and make sure they have a good connection to the body.
Old March 9th, 2016, 08:25 AM
zhthomas
Zach
Where would I be looking to check the grounds? Sorry to ask a dumb question, but I am new to trying to investigate these problems. Really appreciate the help.
Old March 9th, 2016, 09:33 AM
not getting brighter when braking does indicate something is breaking.
Go to your back passenger tire over by where you fill up your gas tank, bring a flashlight along, bend down and look at your chassis behind the tire. You'll see wires coming out from the chassis leading to the backs of your lights. Check the integrity of those wires (there should be about 2' worth) and ensure there aren't any breaks in the wires. From the back of your truck, you should also take a screw driver and unscrew the two screws holding that light in, check the integrity of the bulb, and the contacts within the housing. Best of luck.
Here was a pic of my wiring a few years ago when I had the same issue.
http://www.defendersource.com/forum/...5&d=1347996060
Old March 9th, 2016, 11:15 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
I am in the process of running ground buses back to the battery/frame to eliminate this exact issue. I am sure it is overkill but lights are so darn important
Old March 9th, 2016, 11:38 AM
img tag test
Old March 9th, 2016, 11:41 AM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
While I agree it could be a bad ground, it's worth checking the bulb. If I'm not mistaken it should be a dual filament bulb - with one filament for brake and one filament for running lights. The brake filament could be out.
------ Follow up post added March 9th, 2016 11:42 AM ------
Just read it's a 97... In that case I don't know if it's a dual filament
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old March 9th, 2016, 11:45 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Originally Posted by ontheway View Post
While I agree it could be a bad ground, it's worth checking the bulb. If I'm not mistaken it should be a dual filament bulb - with one filament for brake and one filament for running lights. The brake filament could be out. ------ Follow up post added March 9th, 2016 11:42 AM ------ Just read it's a 97... In that case I don't know if it's a dual filament
or might not be screwed in properly (I've seen that as well)
lamp, part, top
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
FS: (2) Stop/Tail Light Assembly & bulb holder nathanwind For Sale - Parts 9 October 11th, 2014 03:18 PM
Defender 90 Lamp Rear Assembly - Stop & Tail Light aka rover For Sale - Parts 3 July 29th, 2014 01:02 AM
full/partially restored 110 madmoe Wanted 2 September 19th, 2013 07:08 AM
New LED rear tail & stop light bulbs FlaD90 Smaller Projects 2 July 21st, 2008 02:10 PM
