Stock Tire Carrier Bolt size - Defender Source
Old March 17th, 2005, 01:02 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
Does anyone know what the bolt size/thread count is for the stock tire carrier. I am looking for the one that connects the actual carrier to the mount.
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old March 17th, 2005, 02:11 PM
Mark M
Mark Mathews
'94 Beluga Black ST
Hi Joe, I'm buying a Safari Gard tire carrier from Vince today. The current plan is to install it Sunday afternoon. When I'm installing it I'll check out the bolts on the factory carrier and let you know.
-Mark
Old March 17th, 2005, 02:31 PM
I think they are some odd sized machined bolt but I might be wrong. Good luck....
Old May 7th, 2005, 09:12 PM
Antonios
Antonios Hadjigeorgalis
No more
In case you're still looking, the threads are the same as a metric m12x1.75. But the bolt is actually a hinge pin so it's probably a custom part. I think an M12x1.75 65mm bolt with a 15mm diameter x 50mm long sleeve would be a suitable replacement.
Miami, FL
Old May 9th, 2005, 06:03 PM
ShrockWorks
Jim Shrake
The shaft is 5/8" SAE and the threaded portion is Metric, forget what size. How's that for a bastard bolt?
The part below is the stainless steel replacement I used in our tire carriers. It uses a 1/2-13 nut on the end, but it otherwise identical.
McMaster Carr part number: 90298A802
http://www.mcmaster.com/asp/enter.as...p;pagenum=2902
Jim
ShrockWorks - 4x4 Products
carrier, tire, tire carrier
Anyone try these on the stock rear tire carrier Krna Misc. Chit-Chat 2 December 16th, 2005 03:09 PM
35" on Stock Rear Tire Carrier saber6 Misc. Chit-Chat 4 November 16th, 2005 09:45 AM
5 Alloys and stock tire carrier parts cbkearney Wanted 1 October 5th, 2004 07:44 PM
FS/FT Internal tire carrier and Stock Speakers Hans For Sale - Parts 0 January 19th, 2004 03:19 PM
Modified stock tire carrier :) TwisteD90 For Sale - Parts 10 December 12th, 2003 02:38 PM
