Stock Radiators??? - Defender Source
Old November 27th, 2007, 11:42 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Stock Radiators???
So, I'm pretty mad about having to replace my 2 year old, 6,000 mile OEM radiator due to a leak in the bottom. Is there anything else out there that I should look at that bolts up to a 97 w/ oil and trans cooling capacity or just get the stock one fixed. What bothers me is that I typically take it out in the SoCal desert for extended trips and things like this scare me. Any thoughts are appreciated!
Old November 28th, 2007, 01:11 AM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
My radiator is leaking as well
Hi
I too spend a lot of time out in the high desert east of the sierras and death valley. My '97 - 10 year old OEM radiator is seeping fluid out the bottom - I was just about ready to pull it and send it out for repair. So if you find a different radiator that can replace the stock one let me know.
Thanks - Len
Old November 28th, 2007, 05:09 PM
wineryrover's Avatar
wineryrover
Robb
D90, SIII, LR3 & DII
A good radiator repair shop will recore and repair yours and you will be good to go. I have had a shop up in Northern California recore both my D90 and my series. Top work and no problems.
Old November 28th, 2007, 05:45 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I know it's a little far, but S&S Radiator in Oceanside, CA has recored four of my radiators. They do an awesome job and you can mail them your radiator.
Semper Fi!
Old November 29th, 2007, 05:01 PM
that is a short life. are you using distilled water? is it cracked from vibration perhaps?
Old November 29th, 2007, 05:13 PM
It should not have cracked in 2 years. Is it genuine?
Old November 29th, 2007, 06:55 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Speaking of distilled water...what is the current feeling regarding it? Is distilled water good or bad now? It seems like it is like butter & margarine in the media (one week margarine is better for you and the next thing you know someone has done another study and its worse for you than butter) the concensus seems to change with the winds.
Old November 29th, 2007, 07:03 PM
ive always used distilled water.
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Not sure on the distilled water, Inland Rovers has always serviced my vehicle and I know Gordon always uses what is recomended. It is an OEM one, hence my frustration. We sent it out to have it repaired, rodded and pressure tested. In my mind I'm hoping it is better than new with this service!
radiator
Stock height aftermarket springs? lmaldonado Defender Technical Discussions 3 June 29th, 2005 08:23 AM
Stock diff, stock rear axle half shafts..... nilesj For Sale - Parts 5 October 15th, 2004 11:10 AM
Powder Coating Stock Rims Weldon Defender Technical Discussions 6 June 29th, 2004 10:35 AM
Stock parts dave_lucas Wanted 13 January 7th, 2004 09:11 PM
Stock 90 Parts for Sale Joe B For Sale - Parts 2 October 15th, 2003 11:57 AM
