Stock(ish) ride-height suspension upgrades - Defender Source
Old February 9th, 2016, 07:26 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
1988 D110 300tdi/R380
Completely overhauling my 87 110 and am a bit flummoxed on spring/strut upgrade options. Anything is fair game, as I'll be replacing all bushings, mounts, all of it.
What do people recommend for stock-ish ride height, but something a little more beefy? This is both a spring and an absorber question. Any and all advice is requested.
-E
Old February 9th, 2016, 07:54 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I did that last year on my 90 and went with factory HD springs and new standard bushings all around. I run 235/85R16 BFG tires so I don't need any lift to clear oversize tires. I do have an ARB with winch, roof rack and roof tent so I needed the extra capacity of the HD springs. I got about a 1/2" to 3/4" taller stance with the HD springs. I currently have Bilstein shocks but eventually want to upgrade to Koni Raid shock absorbers since I've broken two rear Bilsteins.
Old February 11th, 2016, 10:01 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Other recommendations?
Old February 11th, 2016, 10:18 PM
Stick bushings.
Bilsteins
Google Jim Allen Land Rover spring rate page.,
Old February 12th, 2016, 03:05 AM
Originally Posted by Rocky View Post
Stick bushings. Bilsteins Google Jim Allen Land Rover spring rate page.,
Here: http://www.red90.ca/rovers/springinfo.html
Never a problem with Bilsteins. OME is an alternative
Old February 12th, 2016, 04:14 AM
How in the world do you break rear shocks? At least in a way that would be prevented by buying new shocks?
Something sounds very wrong with the way your truck is set up....
Old February 12th, 2016, 08:10 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
How in the world do you break rear shocks? At least in a way that would be prevented by buying new shocks? Something sounds very wrong with the way your truck is set up....
Off road + wrong bump stops can bottom them out.
Old February 12th, 2016, 09:22 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Broke the top mount off one on a long section of rocky trail in North Georgia when the shock overheated - ugly noises ensued as the top end of the shock tried to beat up the underside of the wheel well. Bilstein replaced that one under warranty.
Broke the bottom mount off another at MAR in 2009 - don't know how that happened.
Look just ahead of the rear wheel in this picture I took as I was just about to leave Eastern Virginia for the 11 hour drive back to Georgia. I bought a used replacement off one of the parts trucks they had there that year.
Koni Raid shocks are much heavier duty.
You can also see the difference in the standard duty versus heavy duty springs in the two pictures.
Old February 12th, 2016, 11:28 AM
Yeah...that sounds like a bump stop issue. No shock will withstand the abuse of bottoming out, regardless of brand name.
Old February 12th, 2016, 03:50 PM
Looks really good with that spring and tire combo!
ht
Report of ride height & ground clearance gains after mods ontheway Defender Technical Discussions 5 June 7th, 2014 11:51 AM
Suspension update and axle upgrades with questions Coug D90 Defender Technical Discussions 0 October 18th, 2013 11:40 PM
RRC seats & Disco springs/shocks (stock-ish) Ray_G For Sale - Parts 2 August 10th, 2011 06:27 PM
Ride Height Measurement Wolf Fabrication Defender Technical Discussions 7 July 24th, 2010 09:58 PM
D90 Suspension Upgrades? Inkopah_D90 Defender Technical Discussions 6 June 16th, 2004 07:12 PM
