Stock alloy offset - Defender Source
Old April 24th, 2006, 11:05 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
Stock alloy offset
I'm looking at buying some used Procomp steelies off a D2. They are listed as 16 x 8 with a 4.25 offset. Compared to the stock alloys where will this move my tires? In a bit? out a bit? about the same? Offsets confuse the hell out of me everytime. I believe that the stock alloys are 16 x7 with a 5.375 offset. There should be no problem moving over my 285/75R16s. I'm just confused about offsets and want to know if I'll be trimming even more fender flare to get them in there. Just to be sure, the lug pattern is the same on a D2 as on a D-90, correct?
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
Old April 24th, 2006, 11:15 PM
I thought D2s had a differnt lug pattern? THats why everyone with D2s can't run the same wheels that we do.
Old April 24th, 2006, 11:26 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
Yep, I finally found the info. D2s run a 5x120mm pattern. A D-90/D1 pattern is 5x6.5. Forget that idea I guess.
Old April 25th, 2006, 08:06 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
You could go with an adapter to make them fit.
Old April 25th, 2006, 10:08 AM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
Nah. If I'm gonna lay out for new wheels I want them to be the right ones. I don't want to 'make' them work. So, anyone got a set of 5 16" steels they want to unload?
alloy, fs
Five all terrains on stock alloy wheels Buckon37s For Sale - Parts 8 April 7th, 2005 10:16 PM
Trade my stock steel rim for alloy dave_lucas Wanted 0 August 12th, 2004 12:12 AM
Stock Disco XD Alloy Wheels and Tires In Washington kpracer For Sale - Parts 1 July 23rd, 2004 08:59 AM
Stock Alloy Wheels/Tires... P1CR For Sale - Parts 13 June 12th, 2004 10:57 PM
Stock Alloy Wheels BENLBENTLEY For Sale - Parts 4 April 16th, 2004 06:50 PM
