Stock 97 auto console mounting location pics? - Defender Source
Old June 12th, 2011, 11:23 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Can anyone post me some pics of where your auto console is screwed/fastened?
I am going install my console from ashcrofts, but just wondering where the stock consoles are actually fastened. I'm sure I can make it up, but it would be nice to see the real mounting spots.
Pete
Old June 12th, 2011, 11:35 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Does this help?
Name:	97 Console Mounting.jpg
Old June 13th, 2011, 10:29 AM
Broncoduecer
peter
D90
Thanks for the pics Ian. So there is only 5 screws huh? 2 on the fuse box area and 3 on the floor. I though it would be more, but that's awesome.
Pete
Old June 13th, 2011, 07:28 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
No problem.
The three at the rear are rivnuts and machine screws into the tub floor. The 2 at the front are trim clips through the side of the console into the clips on the side of the fusebox. They are on mine anyway. If I remember right from the 1 Ashcroft console I have played around with, the rear mounts in a similar fashion so you will need to put in bolts or screws but the front has bolts rather than trim clips. I am sure you could rig it up any way you want though.
If you are using the Ashcroft Shifter bracket with a US sourced shifter assembly, you will need to drill a 2" hole on the passenger side for the lock out solenoid that is fitted to US Trucks. See attached crappy cell phone pics of the one we fitted to a friends 110.
ID:	39623   Click image for larger version
ID:	39625   Click image for larger version
Old June 13th, 2011, 08:47 PM
Broncoduecer
peter
D90
Ian,
I do have the bracket from ashcrofts. So yes, good call on the hole saw. How did you determine the location of the bracket? Did you mock install it and hold the bracket in place to get it in the right spot?
Are those the relays for the start inhibitor and the lock out you have mounted to it?
Thanks for the handy pics, it will be helpful!
Pete
Old June 13th, 2011, 09:25 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Yes, we mocked it up first, marked and measured then cut holes and mounted it. We made a new plate for the middle plate in the seat box to mount everything to. We also used measurements from my 97. That pic in my earlier post is part of one of the ones we took of my truck with a tape measure to help locate the shifter assembly.
Those relays are part of the 14CUX harness that we mounted there under the console. Its an 83 ROW 110 that we transplanted a 95 NAS Disco 3.9 engine and auto trans into. The starter relay we used is the 110 one thats in the fuse box on the bulkhead and the lockout is part of the wiring associated with that.
PM me your email and I'll email you the full set of pics from my truck with the tape measure so you can get an idea. They're about 3mb each though.
97, console, mount
97 D90 with Mud Console and Double Din Stereo bob_o_bean Smaller Projects 16 September 19th, 2012 08:27 PM
NAS 97 Auto Console FS SafariHP The Vendors Loft 2 January 28th, 2009 09:59 PM
Sweet Factory '97 D90 Console for sale! RoverC For Sale - Parts 14 July 30th, 2008 10:09 PM
Pics from Ny auto show 06 Range Rover Mike Hippert Misc. Chit-Chat 11 April 4th, 2005 09:05 AM
Tuffy console '97 NAS 90 with Auto ronward Defender Technical Discussions 5 October 7th, 2003 09:39 PM
