Still frustrated - Can't pass 3400 rpm - Defender Source
Old January 16th, 2007, 11:25 PM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
Angry Still frustrated - Can't pass 3400 rpm
Hello all.
I am still fighting a complete power shut off at 3200-3400 rpm. I have tried the following without sucess:
Neutral check. - No effect, problem remains.
New NGK Plugs,
New MSD Distributer and coil - more power and smoother idle, no change in 3400 rpm fall off.
New fuel filter,
Verified base timing at 6* btdc.
I also checked all of the vacuum connections with brake clean and no leaks were found.
New Air cleaner.
I am idling at ~800rpm. This is at an altitude of 7260'.
The 3.9l is phenomenally stronger running now but still cuts out completely at 3400 rpm. I am running out of ideas at this point. It seems to have a lot of power at 3000 rpm but stumbles and will not surpass 3400 rpm under any circumstances.
Clogged cats would cause an over heating issue correct? I have no temp issues and the D only has 45k miles on it.
I have been unable to locate a fuel pressure gage that will fit the line at the filter so I don't see how I can check the pump. I replaced the fuel regulator with no obvious effect.
Any ideas? This is driving me crazy. It will not reach the speed limit on the interstate due to this, forget passing anything besides grandma on a cellphone.
Old January 17th, 2007, 08:13 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
ECU? Or was that checked in the other thread?
Jimmy Buffett
Old January 17th, 2007, 12:07 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Switch out ECU and test. Any 14cu or 14 cux will work for the test, out of any vehicle with a hot-wire efi system. If still stuck at 3400, start testing all the sensors -- water temp, fuel temp, road speed, etc. ANything that inputs to the ECU.
Doug W.
Old January 17th, 2007, 12:37 PM
Tim Scully's Avatar
Tim Scully
Tim Scully
95 D90 SW/ 95 RR LWB
It could be the ECU but it seems like the engine is running out of air or fuel when you really ask for it to work. I would try to hook up a fuel pressure guage to see what you have there.
Maybe you could use a generic fuel press. guage and a hose with a clamp on the inlet side of the fuel filter. It won't be easy to make it seal but short of making a junction block like the dealers have you don't have much of a choice(unless you could borrow one from a dealer). I don't think there is enough room to get a hose on the fuel lines anywhere to get a good seal with a hose clamp to check it but you could try the connections at the inlet of the fuel filter and the union at the fuel rail to see if you could rig something up.
Tim
Old January 17th, 2007, 02:02 PM
at this point in time it can really only be the ecu.
Ron
Old January 17th, 2007, 09:16 PM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
Thanks guys. I have been unable to locate a usable fuel pressure guage so I will start hunting for an ECU. This has become quite the expensive little gremlin to track down.
Does a 3.9 have a govenor at 3400 rpm? ScottYates Defender Technical Discussions 25 January 17th, 2007 10:45 AM
RPM Fluctuation Billakris Defender Technical Discussions 5 March 28th, 2005 10:52 PM
Engine sputtering chugging between 2650-3200 rpm Heath Defender Technical Discussions 14 February 8th, 2005 08:36 AM
The latest show-stopper: dies at idle, only runs above 2K rpm jaherring Defender Technical Discussions 34 December 23rd, 2004 07:05 PM
Need 10 Spline Pass. Side Front Axel... h2eater Wanted 3 August 14th, 2004 09:57 PM
