Stiffer sway bars? Do they exist? - Defender Source
Old December 2nd, 2003, 02:08 PM
P1CR
Mazen Fawaz
97' D90 SW, Arles Blue
Does anyone make a stiffer anti-roll bar setup?
I use my D90 for towing and would like better on-road performance.
Any help?
Maz
97' D-90 SW
Arles Blue
Old December 2nd, 2003, 02:20 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Scorpion Racing in U.K. make them.
Mike Hammond
Old December 2nd, 2003, 02:22 PM
P1CR
Mazen Fawaz
Does anyone have them as fas as you know?
Maz
97' D-90 SW
Arles Blue
Old December 2nd, 2003, 02:25 PM
You could put airbags in your springs and that would stiffen up your ride.
Old December 5th, 2003, 07:00 PM
mikeslandrover
Mike Hammond
I think Godfrey at Trailmasters was running a set on his 110 when we were all in Morocco lsmmer before last. His truck was certainly motoring along and I had to work hard to keep up, his truck was more laden than mine so I suppose they worked well
Mike Hammond
sway bars Paul Davis Defender Technical Discussions 8 December 3rd, 2007 09:39 PM
sway bars lowering blocks or off rgrrvr Defender Technical Discussions 14 September 5th, 2007 09:19 PM
Sway Bar Disconnect mdmccallum Defender Technical Discussions 12 December 15th, 2004 08:20 PM
Used Front/Rear Set of D90 Sway Bars kpracer For Sale - Parts 0 July 22nd, 2004 01:44 AM
sway bars needed bigrenna Wanted 3 June 3rd, 2004 08:42 PM
