Stereo Wiring Questions - Defender Source
Old June 19th, 2005, 07:39 PM
gtg067i's Avatar
gtg067i
Christian Shea
1997 Defender 90 Wagon
I probably should ask someone at crutchfield all of this but worth a shot as I figure most of ya'll may know a bit about stereos. I am going to purchase 2 pairs of components a 4 channel amp to run them and then use an existing amp to power 2 8" subs hidden behind the jump seats in the crevice between the frames and body panels. I don't want to pay the crazy price to have it installed. I am planning on keeping the Clarion head and cd player. Is this doable and if so what parts will I need to adapt the two amp lineup to the stock head unit? Also, I have my winch wired to the battery, will I need a distribution block at the battery (optima yellow) to hook up that power supply, plus the two amp supplies? Thanks in advance.
I require your largest, cheapest, most alcoholic brewed beverage.
Old June 19th, 2005, 08:10 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
I can offer a little bit of help and a bit more advice. First of all, where do you plan on installing the tweeters? and are they going to be surface or flush mounted? I have some I surface mounted and had to drill the frame of the door to accommodate the depth, scary with the window's glass right there. As far as the subs go, I can't see you fitting an 8" with the amount of space you'll need to provide the correct amount of air for the enclosure. My recommendation would be to get a pair of 6" powered bazooka tubes and put the in the same location. You will have to grind away at the jump seat bracket a bit to make it fit, I have a truck with them installed by a previous owner. this will also cut down on your 2nd amp. I don't know anything about auto wiring, and that's why I had someone do it for me. I would recommend a distribution block with a separate fuse. I would also forget about the rear speakers, you don't hear much from them in the front and the truck is so noisy that it's a waste of money, use the money to buy a better amp and speakers. Just my advice.
stereo, wiring
Wiring questions for split charge system aclarke Defender Technical Discussions 5 April 23rd, 2007 04:39 PM
Stereo Wiring Harness Manufacturer? priest944 Defender Technical Discussions 7 January 11th, 2005 06:03 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
D110 Stereo wiring pcarey Defender Technical Discussions 1 November 23rd, 2003 10:57 PM
