Stereo Wiring - Defender Source
Old May 22nd, 2009, 03:22 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Stereo Wiring
Trying to figure out why the Right Front speaker stopped working today. Installed new Polk speakers and they were working great. THen the right front one made a beeping noise and then stopped working. WTF?? Does anyone know how I can check the output for the speaker at the factory amp under the seat? Is there a diagram for these wires? The truck has a Poineer head unit in it by the way
Legend in My Own Mind.
Old May 22nd, 2009, 06:36 PM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
You rebuilt this truck from nuts and bolts and this is a problem , NOWAY D-90 GURU , and I wanted to become your pupil . Randy just be happy you can hear any music , all I hear is that loud HUM from the tires but I still wouldn't change a thing .
Old May 22nd, 2009, 06:43 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
LOL... I just don't get the whole Radio wiring setup in ths thing...
Old May 22nd, 2009, 07:06 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
What? You built the "whole" truck right? I don't understand how you can build it, but can't figure this out....are you serious or just messin around?
What tree?
Old May 22nd, 2009, 07:34 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Dammit guys... I just need a diagram and I would be good to go. No one ever seems to have answers when it comes to diagrams for a 95 SW. I don't know much about how the amp is wired in.
Old May 22nd, 2009, 09:12 PM
JRW's Avatar
JRW
94 D90 ST #1247
Wish I could be more assistance, but my 94 did not have the factory AMP when I got it. However, it did use the factory speaker wiring. If your is the same way, you should be able to put a volt meter across the wires and see if you are getting anything. If it is only a single wire like I have read about, then the ground is probably to the main frame ground.
If you are getting something on the wires, you could always try plugging in another speaker you know works to see if the speaker died.
Old May 23rd, 2009, 12:44 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Randy, is there no wiring diagram for it in the manual I gave you?
Old May 24th, 2009, 01:21 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ok. I figured out the wiring and found that the speaker signal for the right front speaker works fine into the stock amp but coming out of the amp, that channel is dead. Anyone have a stock apm I can borrow to try?
My guess is that the stock amp is screwed up on that channel.
Old May 24th, 2009, 01:41 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
X2. I'd just remove the stock amp anyway. Just about "anything" in the aftermarket would be better than factory. Just my .02
What tree?
Old August 24th, 2010, 05:55 PM
can you keep the stock head unit and replace the factory amp?
Old August 25th, 2010, 08:38 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Randy, I second dumping the oem amp. Go with a powered sub instead.
Old August 25th, 2010, 08:09 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Delete...
Old September 27th, 2010, 12:49 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have a new in box factory amp if anyone is interested.... It did not fix the prob in my fathers truck. I am just removing it now... He cant hear well anyway and listens to sports radio on AM anyway....lol
stereo, wiring
Stereo Wiring Questions gtg067i Defender Technical Discussions 1 June 19th, 2005 08:10 PM
Stereo Wiring Harness Manufacturer? priest944 Defender Technical Discussions 7 January 11th, 2005 06:03 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
D110 Stereo wiring pcarey Defender Technical Discussions 1 November 23rd, 2003 10:57 PM
