Stereo - no power from battery - Defender Source
Old January 20th, 2012, 07:00 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
In preparation for a new Alpine head unit from Crutchfield (CDE-133BT), I cut out the hack job that connected the aftermarket stereo, the Arb compressor switch, the Arb rear locker switch, and rear work light wiring that I found in the console. I cleaned everything up, bought a bunch of Posi-Locks, printed off the stereo wiring diagram, and re-wired it.
Now, the new head unit won't fire up and I am getting zero juice at the purple battery wire on the truck's stereo harness. What could I have done to the Defender's stereo wiring harness that I have no power there now? I realize this is probably like asking how many zebras are in Mozambique, but maybe someone has had a similar experience? I thought the power wire should always have 12V?
Old January 20th, 2012, 07:17 PM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
Did you check the fuses? I believe there are 2 under the dash under that tray...
Old January 20th, 2012, 07:32 PM
Defros
dima
1997 defender 90
I bought a head unit from crutchfield and tried to install it yesterday. I also have a '97 and my system was stock, so I purchased a vw harness and used it to connect the kenwood I purchased. The tech department was no help on getting the unit to work. I had finally established power to the unit, but the unit would not make any noise. You need to connect the yellow with purple stripe wire, because that is for amplifier power. It should be connected to the remote power on your unit. Once you do that you should be good to go. I do understand you are saying you are not getting juice to the purple wire, which is odd. The fuses are the obvious first look, but I figure that was the first place you looked. Hope this helps you.
Old January 21st, 2012, 07:31 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
When I bought my 97, it was hacked up as well. After a week of messing with the rat nest, I have up, bought a simple relay for ignition switched power and started over.
Really glad I did. Now I know what's what and can make sense of where everything goes.
Old January 22nd, 2012, 09:15 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Purple is "Accessories fed direct from battery via fuse" I would look for a fuse even if it was one somebody put an extra in someplace.
Land Rover 110
Old January 22nd, 2012, 12:26 PM
jefferson's Avatar
jefferson
Jeff A
97 Defender 90 SW #593
This thread was useful when I replaced my radio:
http://www.defendersource.com/forum/...eferrerid=6091
My harness had not been hacked up, but this still served as an excellent reference. I took the stock amp out of the system and used the Metra 70-9400 harness adapter from Crutchfield.
A note about this adapter: it includes only a single common ground wire for the speakers, whereas the trucks harness has seperate grounds for each speaker. I had some extra pins laying around, so I added the additional speaker ground wires for a clean fit.
Because I took the amp out the yellow w/ purple wire was not used. The new head unit seems to provides sufficient amplification (for me at least).
If you ditch the factory amp be sure to connect up the ground wires that pass through it, to ensure that you are able to communicate with the ECU and retrieve check engine codes.
Old January 22nd, 2012, 03:06 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
So it was a fuse. But as Mike noted, not a factory one. I've been removing miles of wire, poor crimping, miscellaneous fuse holders, boxes, etc, etc, etc. I guess this truck had a lot of accessories at one point and the PO hacked into the closest wire he could find it seems.
Bluetooth music streaming from my iPhone 4S and finally handsfree calling. I'm going to add that Alpine PowerPack and that should be enough fidelity for my music tastes. Thanks for the help guys.
battery, stereo
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Switch/Wiring Question: Stereo Ignition Power Override nimbusnic Defender Technical Discussions 3 June 30th, 2008 01:05 AM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
