Stereo Install Questions - Defender Source
Old November 29th, 2011, 12:12 PM
jefferson's Avatar
jefferson
Jeff A
97 Defender 90 SW #593
I am preparing to install a new stereo (aftermarket) in my 97 wagon. I have the appropriate harness adapter, etc. I would like to bypass/remove the factory amp from the system as the new headunit should be sufficient, and wonder if someone can recommend a "clean" way to bridge the inbound and outbound wires (speakers and grounds) that does not involve cutting off the two male plugs that connect to the amp.
I'd like to keep everything reversable, even if I have no intention of adding that amp back into the system. But if the easiest solution is to cut and add new connectors I guess thats fine. Also, let me know if there are compelling reasons to leave the amp in place.
Regarding speakers - I am going to try the stock speakers and wire first. If it sounds like total crap, I'll run new wire. But the speakers sounded fine before the stock stereo gave out.
Also, does anyone know whether the center dash console that currently houses the rear door heat/wipe/wash buttons in a SW will accomodate the new stereo, assumming the buttons and mounting plate are relocated? I cant tell whether that is a seperate part from what RN and RDS offer as a radio housing.
Thanks.
Old November 29th, 2011, 02:18 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Smile
no not deep enough, i used one from radio shack looks like it was made for it
Old November 29th, 2011, 03:20 PM
jefferson's Avatar
jefferson
Jeff A
Thanks, Ron. I'll check out that Radio Shack one.
Old November 29th, 2011, 04:02 PM
ron's Avatar
ron
Ron
or get the mud uk unit and have all switches and radio in on place
Old November 29th, 2011, 05:04 PM
Rugbier's Avatar
Rugbier
Gustavo
Jeff I'll check to see if I have the original housing that came in the 110, it had the radio in it
If I find it , it is yours
but I want a pack of beer for it ...available in Indiana *LMAO*
NO SIGNATURE
Old November 29th, 2011, 05:28 PM
jefferson's Avatar
jefferson
Jeff A
Thanks, Gustavo. That would be awesome.
Old November 29th, 2011, 07:27 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Becareful, ECR has a page on their site about cutting out the factory amp in a 97 D90. If you cut it out, your code reader OBDII output on the truck will die. Or at least, thats what I read.
Robert Deniro
Old November 30th, 2011, 08:36 AM
Rugbier's Avatar
Rugbier
Gustavo
Jeff,
Here it is ( needs cleaning but it is as new )
Not sure if you need the harness, but I have a brand new one as well
NO SIGNATURE
Old November 30th, 2011, 09:49 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
The grounds in the amp relate the EFI ECU.
You have to connect all the black wires together when you delete the factory amp otherwise your OBD2 reader will not function. Its simple, just something stereo shops don't know anything about.
Email:
Old November 30th, 2011, 12:41 PM
jefferson's Avatar
jefferson
Jeff A
Thanks, Gustavo. Maybe I can get that from you if we have a HH this month? I have the harness, but thank you for the offer.
I am aware of the ground issue at the amp but thanks for the heads-up. I guess I was looking for a way to bridge the wires that pass through the amp (the speakers and ground) once the amp is removed. I just dont want to cut off the stock plugs if it can be avoided. Not sure if there is a multi-pin male-to-male connector that would work in this case.
Old November 30th, 2011, 01:21 PM
Rugbier's Avatar
Rugbier
Gustavo
Jeff, u r welcome
BTW, if we do not have a HH this month , I will see Jason in a week or two, so I will give it to him regardless of HH
Now about that beer from South Bend Indiana *LMAO*
NO SIGNATURE
Old November 30th, 2011, 08:57 PM
jefferson's Avatar
jefferson
Jeff A
Perfect. Thanks Gus. Indiana beer coming your way .
Old November 30th, 2011, 09:46 PM
Maybe get a plug the same as the amp side, and bridge the wires there? Then you just plug that in to the harness. Or just bridge the pins with individual wires using male or female spade connectors. I'm not sure what the plugs look like, so just guessing.
Originally Posted by pendy
I'm here for the D's
Old November 2nd, 2013, 11:10 PM
D110
Jamie
1955 107
I know this is an old thread, but I'm bypassing the factory amp and just going straight from my new head unit so I want to make sure I do this right - going into the factory amp there is one black wire, coming out there appears to be two - do I join all three together?
Thanks!
Old November 3rd, 2013, 02:01 PM
D110
Jamie
1955 107
Ok it was late and I didn't have the best light - on looking at it today it appears that there are only two black wires which I assume I need to join together - can I rip everything else out?
I've attached a pic for reference - the plug on the left has 8 wires which appear to be speaker outputs. The other plug on the right has 13 wires which I assume are 8 speaker input, 2 green fused power, 2 black ground and a yellow/purple stripe that is the power on from the head unit. Could someone confirm this is correct and all I need to worry about is joining the two ground wires. Thanks!
stereo
safarigard bumper install questions. Firefighter2904 Defender Technical Discussions 11 August 10th, 2011 01:26 AM
Planning Amp Install - some questions Chaucer Misc. Chit-Chat 7 February 25th, 2010 04:00 PM
Stereo Wiring Questions gtg067i Defender Technical Discussions 1 June 19th, 2005 08:10 PM
Stereo Install In Dash caschumann Defender Technical Discussions 18 November 4th, 2004 12:41 AM
PIAA 90 PRO XT (top) install questions... norros Defender Technical Discussions 22 June 30th, 2004 05:31 PM
