stereo doesn't work, but everything else does. - Defender Source
Old April 27th, 2012, 01:02 PM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
The radio was fine for up until a week ago, I started the truck and it didn't work. Two days later it did, now it hasn't worked the past three times using the truck. Any suggestions, is there a fuse or something I can focus on here? I have a 1997 NAS D90.
Thanks.
Old April 27th, 2012, 01:49 PM
Is it original?
Generally stereo's have 3 live feeds .... one that is constant to provide memory backup, one that switches with the accesory on the ignition switch and one that connects to the lighting circuit to provide illumination when you switch the headlights on.
So when it doesn't work ...
Does it illuminate with the headlights? if not - likely earth on the radio
When it does work - are the memory pre-sets stored? - likely main power connector. Older aftermarket radios had inline fuse holder which may cause problem.
Old April 27th, 2012, 01:59 PM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
Is it original?
No it's not, I'm getting a new one in a couple days.
Feeds:
Got it, don't remember if last time it worked if the stations where pre set still. The stereo was always illuminated.
Currently there's NO power at all, earth on the radio?? do you mean the ground? If so where do i find this, I'm assuming near the battery correct? Funny thing is it just worked 4 days ago.
Thank you
Old April 27th, 2012, 02:06 PM
I'd just get the new one and see if that fixes it.
Are you planning to install yourself ( I could assist if you need) or have it done by a shop?
yes sorry earth in the UK - ground in the US ... spending too much time in canada at the moment and they use a lot of british words ...
stereo
stock stereo trouble 95st Brent Nevin Defender Technical Discussions 5 April 8th, 2010 07:49 AM
Various D90 Parts - OE Stereo/ CD Changer/ Brush Guard TurkD90 For Sale - Parts 1 July 30th, 2005 03:15 PM
Stereo Wiring Harness Manufacturer? priest944 Defender Technical Discussions 7 January 11th, 2005 06:03 PM
not safe for work lobster Misc. Chit-Chat 10 November 5th, 2004 06:51 PM
Custom Work mgrgpg Misc. Chit-Chat 6 November 14th, 2003 08:59 AM
» Defender Registry
Blu
Cred
TOAD
SaltyDog
Add your Defender
