Stepper Motor Cleaning - More Details Please - Defender Source
Old November 2nd, 2011, 11:17 PM
brettm's Avatar
brettm
Brett
97 D90-SW, Arles +4.6
Plenty of great threads pointing to the simple task of "clean your stepper motor" as a step to troubleshoot idle issues.
I just pulled mine and cleaned it, however, I have a few more detailed questions I can't find the answers too...
1. Cleaning the stepper motor itself seems an obvious procedure, .. and the faces where the plenum/stepper meet the gasket, but what about the hole it came out of? How far in there should you clean, and what's the best thing to clean the hole with? carb cleaner?
2. How 'dirty' is a dirty stepper motor? Mine had minor black film over the pointy bit at the end, but wasn't especially filthy. I'm kind of looking for an assessment of "oh yeah that gunky mess for sure is the idle-issue culprit", vs . "huh, looks pretty clean/normal, onto the next thing..".
appreciate the pointers o-wise-ones.
Old November 3rd, 2011, 05:08 AM
Did it fix your problem?
No matter how much I have cleaned the stepper motor the housing or the throttle body any time I have pulled the plenum there has been some "gunk" to clean.
Old November 3rd, 2011, 08:22 AM
They're cheap enuf that it's better to just get a new one if yours is in doubt. However a light coat of carbon does not seem to be excessive crud. Untold gazillions of GM cars and trucks use this exact part.
The stepper motor is an adjustable air bypass device that opens and closes the hole by means of a screw driven plunger (the pointy thing). The ECU operates the "motor" that spins the screw drive mechanism depending on how much bypass air is needed. Usually on deceleration, the bypass airway opens to keep the engine from bogging and stalling.
Old November 3rd, 2011, 12:15 PM
brettm's Avatar
brettm
Brett
not sure.. its happening pretty sporadicly, so too early to tell. this is fleabus's old truck, and idle issues are not new to it (http://www.defendersource.com/forum/...ead.php?t=7057)... but they're re-surfacing after a multi-year vacation.
Old November 3rd, 2011, 04:00 PM
I am not up to speed on the GEM's trucks but it seems there is very little to go wrong other than 8 coil packs wires and plugs.
Background is nice, mileage whats been replaced how well has it been maintained? I generally throw parts at problems due to my lack of trouble shooting skill this generally solves my issues. Id say if its not throwing codes has good plugs and wires run some techron through it and flog it.
Old November 3rd, 2011, 06:48 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Keep in mind that vaccum leak problems are often to blame. These can be actual gasket leaks or hose leaks. Choke spray in the engine bay around all probable areas are the first thing I try... If the engine RPM goes up, you got a leak.
Old November 4th, 2011, 12:39 PM
brettm's Avatar
brettm
Brett
Thanks for the suggestions guys - I'll spin up another thread with all the maintenance history etc, maybe it will jog some thoughts... there's some ECU history worth mentioning. I'll try not to hijack this thread and keep it on-top of what to look for when cleaning the stepper.
Sadly, stepper cleaning didn't fix me, she stalled again yesterday.
Old November 12th, 2011, 01:37 AM
brettm's Avatar
brettm
Brett
quick update: i replaced the stepper with Napa/Echlin part. so far so good... 3 days stall-free...
Old November 12th, 2011, 02:03 AM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
brett...what napa part number. Need to pick one up for my 97 as well.
Old November 12th, 2011, 11:38 AM
brettm's Avatar
brettm
Brett
Product Number: CRB 21856
Price: $68.33
http://www.napaonline.com/Catalog/Ca...856_0213481115
Old November 12th, 2011, 11:48 AM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
thanks.
Old April 26th, 2012, 10:20 AM
tdn's Avatar
tdn
Troy Norton
'94 D90
does this part come with a replacement gasket? I need to pull mine out and clean it first to see if that clears the code but I read in workshop manual about replacing the gasket when re-installing. Anyone know about this?
Old April 26th, 2012, 10:53 AM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
I have cleaned mine out once in 3 years. I always use throttle boddy cleaner and some clean rags. I didnt replace the gasket, but I did notice that the vaccum line going from the throttle boddy looked bad. When I grabbed it to pull it off, it fell apart. No more stalling since.
Old April 26th, 2012, 11:10 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
This is where I got mine. Works like a charm.
http://www.amazon.com/gp/product/B00...ls_o03_s00_i00
1997 P38 4.6
1998 P38 4.0
2011 LR4
motor
Stepper plunger worn oddly wicks Defender Technical Discussions 2 September 21st, 2005 09:25 PM
Code 48 Stepper motor devinchi Defender Technical Discussions 8 September 8th, 2005 05:43 PM
Stepper motor same on RR? waveridin1959 Defender Technical Discussions 15 December 16th, 2004 10:52 AM
dirty stepper??? ttegt Defender Technical Discussions 1 March 31st, 2004 10:37 PM
stepper motor erik d Defender Technical Discussions 2 February 11th, 2004 04:09 AM
