Stepper motor - Defender Source
Old November 10th, 2011, 01:30 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
Stepper motor
Engine light is on. Code says stepper motor. Took it off and cleaned it, reinstalled, cleared code and light came back on. Periodically the idle will stay up around 1100 rpm for a few seconds. Seems to me it might need to be replaced. Any thoughts or ideas?? Is it as simple as screwing a new one in and lugging it in? Or does it have to be set/adjusted?
That is why it is called a short cut. If it was easy it would just be "the way."
Old November 10th, 2011, 01:43 PM
RickM
Rick Mabus
95 D-90 ST
I am dealing with similar issues. Apparently there is one other thing to check and it is at the air intake side. There is a "bypass" hole in the throttle body assembly that will need cleaning. There is a discussion on it right now relating to stalling that discusses this.
Old November 10th, 2011, 01:45 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
I bought one that would work on a chevy astro van for around 30 bucks and just screwed it right in.
http://www.rangerovers.net/rrpartsv.htm#stepper
Ive also run seafoam through it and that helped with my idle issues. My truck had a lot of carbon build up though.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old November 10th, 2011, 03:35 PM
RickM
Rick Mabus
95 D-90 ST
Thats a great article. I will be picking one of those up asap as I think this will be my next and personal project for the weekend.
Old November 10th, 2011, 06:02 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
thanks for the parts article, and the suggestions
motor
Code 48 Stepper motor devinchi Defender Technical Discussions 8 September 8th, 2005 05:43 PM
Installing a Napa Stepper Motor p# 2-1738 Heath Defender Technical Discussions 0 January 13th, 2005 10:04 AM
Stepper motor same on RR? waveridin1959 Defender Technical Discussions 15 December 16th, 2004 10:52 AM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 02:16 AM
stepper motor erik d Defender Technical Discussions 2 February 11th, 2004 04:09 AM
