Steering wheel rub - Defender Source
Old June 21st, 2011, 12:21 AM
Rochebm
Brandon Roche
97' SW #485
Steering wheel rub
The back of my steering wheel seems to be rubbing on the plastic housing for the steering column. The noise it makes when I turn the wheel is almost as annoying as my window rattle. I pulled the steering column housing off to look for the culprit, but had no success. Any suggestions? Do I need to loosen the wheel?
Old June 21st, 2011, 12:43 AM
bjf's Avatar
bjf
barry f
94 ST #395
Time to sell the truck. Every time I solve one rattle two new ones come up.
Old June 21st, 2011, 01:05 AM
Chaucer
Will
93 110 | 97 90
Try to loosen the screws on the plastic housing and see if the wheel rub stops. It could be that the screws are a little too tight, and it causes the housing to flex or bulge.
Old June 21st, 2011, 05:19 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Just grind down the plastic rib where the two pieces come together a mm or two. I had a momo hub adapter I bought from UK that rubbed and that was my final solution.
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old June 21st, 2011, 08:37 AM
reb78
REB
Land Rover 110
This worked for me too. I just took a file to the housing where it was rubbing on my moto lita adaptor
Old June 21st, 2011, 09:12 AM
Naplm00
Matthew
I just tightened it up then removed the wheel and filed down the face of the plastic housing with a rasp. Worked great! Mine was so bad it would catch on the plastic and almost pull it off
Old June 29th, 2011, 03:23 AM
Rochebm
Brandon Roche
97' SW #485
Filed down the face of the plastic behind the wheel and the noise is almost completely gone. I need to find the time to take a little more off. Thanks for the advice, everyone.
wheel
removing steering wheel Hollywood Defender Technical Discussions 25 August 15th, 2010 03:16 PM
Steering wheel adapters Buckon37s Defender Technical Discussions 109 July 1st, 2007 09:19 PM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
