Steering Wheel Removal - Defender Source
Old January 18th, 2006, 01:46 PM
sbfall96
Jeff Edwards
1995 D-90
Question Steering Wheel Removal
Ok... my situation... The current steering wheel I have on my 95' D90 needs to be replaced. I have a replacement already so my issue lies with what happened while trying to remove it. I used a steering wheel removal kit (2 bolts + bar for leverage). One of the bolts broke off into the steering wheel... then the screw extractor bit broke off into the bolt within the steering wheel. It seems that no drill I have can drill out the extractor bit (been told its impossible) so... my question Is there another way of removing the steering wheel beside using the usual method since I cant use one of the holes in the steering wheel now ????
Thanks!!!
Old January 18th, 2006, 02:52 PM
Have you tried hitting the extractor bit with something like a punch? They are pretty brittle and break fairly easy.
Old January 18th, 2006, 03:52 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
No need for the extractor to begin with. give the wheel a good pounding from the column side with a mini sledge. Watch your face though. Catcher's mask would work well.
Old January 18th, 2006, 05:14 PM
sbfall96
Jeff Edwards
1995 D-90
I think I'll try giving it a good pounding. Since the center bolt is loose what exactly is holding it on so tight anyway? Is it just the two metal brackets on the back of the steering wheel that make it fit so tight?
Old January 18th, 2006, 05:20 PM
crobinson
Chris Robinson
97' D1
Spray some penetrating lube around the splines then try hitting it with a hammer after it has sit for a awhile. If that still doesn't work drill out the broken screw with a larger bit and screw in a self tapping screw.
Old January 19th, 2006, 03:02 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
The screw extractor is hardened steel, and a normal HSS bit won't touch it. Maybe a colbalt bit might, but usually its impossible to do since the extractor fragment is so jagged the bit wanders off it.
Do you have a Dremel? Get a little solid carbide milling bit; I've used this to grind out the fragment of the extractor. Then I use a left-handed drill bit to drill out what's left of the screw.
--Barry
Old January 22nd, 2006, 03:33 PM
Hollywood
alex howell
94 d90
I had the same problem. Nothing worked...except a mini sledge hammer and 5 minutes of stress relief.
wheel
removing steering wheel Hollywood Defender Technical Discussions 25 August 15th, 2010 03:16 PM
Steering wheel adapters Buckon37s Defender Technical Discussions 109 July 1st, 2007 09:19 PM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
Steering wheel removal? howellm70 Defender Technical Discussions 5 February 5th, 2004 06:14 PM
