Steering wheel removal? - Defender Source
Old February 2nd, 2004, 09:11 PM
howellm70
Michael Howell
Maybe a naive question but how do you remove a steering wheel in a D-90?
Old February 2nd, 2004, 09:43 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Pull off the padded cover trapezoid by hand. Yank it! There is a big center bolt - undo it. Get or fabricate a stiff piece of metal with two holes in it that will line up with the empty screw holes in the wheel itself, on either side of the steering shaft. Find two bolts about 1 1/4 inch long that will fit the threads (don't know the size). Screw in the bolts, a little each side, and watch as the wheel starts coming up off the steering shaft!
Or you could buy a wheel puller at a parts house -- don't know the cost.
DW
Old February 2nd, 2004, 11:18 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Or,
Loosen the large nut in the middle of the wheel all the way to the end, spray it down with wd-40 then sit in the drivers seat and bang the shi-iatt out of it towards you. It will pop off. Make sure you leave the nut loosly on the end of the tread, if not that wheel will come off and hit you right in the face. --no comment.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old February 3rd, 2004, 01:20 AM
tbmcneill
Guest
Posts: n/a
D-
...& I thought I was the only one..
T
ps-3 weeks and counting...
Old February 3rd, 2004, 01:47 AM
Doug's Avatar
Doug
Doug Walker
lmao u guys. Yeah, that'll work!
Old February 5th, 2004, 06:14 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I made a puller just as described I think the thread size is BA anyway it's an imperial size.
You can also get the wheel off by removing the big nut in the center and then rocking the wheel side to side, sounds unlikely but it works. You don't even need to pull very hard whilst doing it. I rarely bother with the puller I made as the wheel always comes off with the latter method.
Mike Hammond
wheel
removing steering wheel Hollywood Defender Technical Discussions 25 August 15th, 2010 03:16 PM
Steering wheel adapters Buckon37s Defender Technical Discussions 109 July 1st, 2007 09:19 PM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
