Steering Wheel Lock-Up - Defender Source
Old August 6th, 2014, 02:13 PM
brettm's Avatar
brettm
Brett
97 D90-SW, Arles +4.6
Yesterday, I'm going about 20mph and in the middle of a right turn - brakes applied - wheel is about half way turned, when the steering wheel locks-up. Like it won't turn at all, I wiggle it really hard - then it makes a popping noise and goes back to normal.
This happened once before about 6 months ago, but has never happened again until last night. I was also braking and turning right when it happened that other time. I remember that one well - I as thought I was going to plough right into the cars waiting at the intersection
Anyone ever had anything like this? Is it an early indicator of something worn in the steering column?
Old August 6th, 2014, 02:16 PM
the rover shop
shayne young
Did it lock in the same position of rotation as the steering lock does..usually steering wheel in straight ahead position.. Not the steering itself.. But the steering wheel..
Old August 6th, 2014, 02:36 PM
You should do all your braking in a straight line .. racing line ... slow in ... fast out! ;-)
Old August 6th, 2014, 03:13 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I'd be looking for a possible kinked power steering line.
Or is it more like locking as if you removed your ignition key?
Black Rhino Lives Matter
Old August 6th, 2014, 03:18 PM
Check the steering arm ... could be one of the knuckle joints is stiff / worn out.
Old August 6th, 2014, 03:21 PM
brettm's Avatar
brettm
Brett
no - the steering wheel was half-turned to the right, way past the lock position. it felt different too - when the "steering lock" is on with key-out it has some wiggle room left and right. this was just hard-locked in one spot, wouldn't budge a bit until i yanked on it.
------ Follow up post added August 6th, 2014 12:23 PM ------
it felt different too - when the "steering lock" is on with key-out - as when that happens there is usually some wiggle room left and right. this was just hard-locked in one spot, wouldn't budge a bit until i yanked on it.
Old August 6th, 2014, 04:53 PM
brettm's Avatar
brettm
Brett
So I take back that previous comment...
I played with the "key out" steering-lock and the position it engages when the wheel is turned to the right is pretty much where the s.wheel position was when I was driving. Interestingly the steering-lock does not come on when the steering wheel is turned to the left.
Sounds like it might be related to that lock mechanism.
Old August 6th, 2014, 08:56 PM
the rover shop
shayne young
I'd be putting a new steering/ignition lock in it.. Very cheap and easy to do.. I don't have to tell you that you were very lucky, it could have been wayyyy worserer..
Old August 6th, 2014, 09:10 PM
check the universal joints on the steering shaft under the hood.
Old August 6th, 2014, 10:18 PM
Check your front CV's. I've seen a broken CV wreak havoc with steering. Though you might notice the lack of forward momentum. Check em anyway...
wheel
Wheel Spats - Steering Wheel - Loadspace - Floor Mats Rugbier For Sale - Parts 21 November 20th, 2012 08:29 PM
Wheel arches (spats) Steering wheel dash parts tomaco1 For Sale - Parts 6 April 10th, 2012 12:50 AM
Quick Steering Fix - play in the steering wheel. bossman429 Defender Technical Discussions 5 February 27th, 2012 08:37 PM
For Sale: Defender Steering wheel adaptor for Mountney wheel SeattleRRC For Sale - Parts 2 February 11th, 2009 04:46 PM
Wheel Adapter - NOT steering wheel nikojo Defender Technical Discussions 0 June 9th, 2008 12:49 AM
