Steering stabilizers - Defender Source
Old August 22nd, 2013, 10:20 AM
Any thoughts on the 3 available steering stabilizers
OEM -
Bilstien
OME
I am planning on doing the OME springs and shocks to replace my old & tired oem ones.
looking for any impressions or suggestions
95' D90 - daily driver..
Old August 22nd, 2013, 10:31 AM
Have you adjusted the pre-load on your hubs ... that along with the bushes is the largest contributor to front end stability.
Old August 22nd, 2013, 11:14 AM
OME was a nice band aid and it is still doing well. Swivel pins and front wheel bearings make the biggest difference here.
Old August 22nd, 2013, 11:43 AM
Ray_G's Avatar
Ray_G
Ray Gerber
I've had all three, no real differences that I've noticed. If just doing it because the suspension is old, go with what is least expensive or matches the other stuff is what I'd suggest-particularly since you gave no indication that it is to offset swivel preload issues or what have you.
r-
Ray
Old August 22nd, 2013, 11:52 AM
It was just a replacement issue rather than trying to fix a wobbly front end. Hubs have already been rebuilt in the last 15k miles.
I want to gain a little height and replace my old shocks/springs is all. Ill probably do the bushings as well
Old August 22nd, 2013, 02:02 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
FWIW, I had a non genuine oem style that didn't last well - Boge maybe. I didn't want a bright yellow one on the front. Get the woodhead genuine if you go that route. In my experience, a bad stabilizer does cause shimmy at certain speeds.
"Uhh...I think they all leak like that."
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Steering wheel adapters Buckon37s Defender Technical Discussions 109 July 1st, 2007 09:19 PM
Steering problem! TwisteD90 Defender Technical Discussions 3 June 2nd, 2005 02:55 AM
Loose steering kellymoe Defender Technical Discussions 2 October 15th, 2004 08:42 PM
