Steering Stabilizer...will it help? - Defender Source
Old November 26th, 2003, 09:29 AM
P1CR
Mazen Fawaz
97' D90 SW, Arles Blue
I have 33x12.5s and a stock steering stabilizer. The truck mildly pulls side to side when braking on uneven pavement.
Will upgrading my stabilizer (in addition, replacing the original, 50k mile stabilizer) help this?
If not, what exactly will it do? and what is the best upgrade?
I have only seen OME version and a Bilstien
Thanks!!!
Maz
97' D-90 SW
Arles Blue
Old November 26th, 2003, 09:34 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Nice, another '97 Arles owner!
The stabilizer might help. I would go with OME. I've had both and believe the OME is a better unit.
But really the pulling could be just about anything. Is it only in hard braking, or anytime you brake? I would check to make sure all of your components are bolted tight on the front end. Make sure your track rod ends/ball joints are still good. But pretty much this could be an endless road depending on how straight you want your braking to be. I have slight pull with my 33's to the right hand side only under hard braking.
Old November 26th, 2003, 09:42 AM
I found that when I drive with the tire pressure at 25 psi it pulls more then when I have the pressure at 35 psi.
Old November 26th, 2003, 09:47 AM
P1CR
Mazen Fawaz
What else will the stabilizer do?
I just finished restoring my truck. Every panel was taken down to metal, and repainted. Replaced all 3 doors, all hinges and bolts (ss) I had the tire carrier made and got new wheels and tires.
Just picked it up last week. It took a month and a half. I love it.
Maz
97' D-90 SW
Arles Blue
Old November 26th, 2003, 09:57 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Looks awesome Maz. That's a clean truck.
I do run high tire pressures to improve handling and mpg (silly, I know). I run the fronts at about 40 and rear in the 46-48 range on road.
Old November 26th, 2003, 10:29 AM
P1CR
Mazen Fawaz
Thanks David.
where the hell is Masshole??
That's an unfortunate name.
Maz
97' D-90 SW
Arles Blue
Old November 26th, 2003, 10:59 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
That's the name most of us get as MA residents. Typically for either our erratic driving, or general attitude.
Old November 26th, 2003, 11:08 AM
P1CR
Mazen Fawaz
HA!!
thats great.
I'm considering moving back out to the East Coast. (I'm from MD).
I hate it here.
Anyone else on this board share the misfortune of living in the armpit of North America? (Michigan)
Are there regional D90 club type things?
Maz
97' D-90 SW
Arles Blue
Old November 26th, 2003, 12:30 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Stabilizer won't help, I don't think. Pulling is either alignment or brakes. Check current thread no this board about pulling to left. Alignment is possible since u just had the truck all apart.
Doug
Old November 26th, 2003, 01:34 PM
The steering stabilizer only masks problems. I don't have one and there are zero steering problems.
Old November 26th, 2003, 01:51 PM
vnrover's Avatar
vnrover
Paul Huynh
1997 D90 ST #1302
I can't imagine that there's a lot of Mazen's living in Michigan... but I could be wrong.
Mazen, did you work with IBM at the DaimlerChrysler Customer Service Center?
Old November 26th, 2003, 01:55 PM
P1CR
Mazen Fawaz
Umm...nope.
must be another. I've only met one other, and he was on the other side of the planet.
Maz
97' D-90 SW
Arles Blue
steering stabilizer TravelerBT Defender Technical Discussions 5 March 6th, 2009 09:01 PM
Steering stabilizer... Death Wobble.. TDI Guy Defender Technical Discussions 13 September 15th, 2008 12:27 PM
OME Steering Stabilizer broder Defender Technical Discussions 1 January 4th, 2006 12:01 PM
steering stabilizer jimmy salmon For Sale - Parts 0 May 10th, 2005 12:44 PM
» Defender Registry
"Pete"
Overland90
D90
bneri
Add your Defender
