Steering Stabilizer - Defender Source
Old November 11th, 2009, 10:41 AM
bjf's Avatar
bjf
barry f
94 ST #395
Steering Stabilizer
How do you know when you need a new one and which one do you get?
Old November 11th, 2009, 10:56 AM
When you can compress it and it does not bounce back...
Old November 11th, 2009, 11:32 AM
enjoi1968's Avatar
enjoi1968
Blake Pendleton
98 D1
I like my OME stabilizer...
Old November 11th, 2009, 11:58 AM
bjf's Avatar
bjf
barry f
94 ST #395
can you tell without taking it off
Old November 11th, 2009, 12:51 PM
bjf's Avatar
bjf
barry f
94 ST #395
well it is 16 years old so possibly could have leaked out a long time ago. I just find the steering in my 90 to be more precise than the 110
Old November 11th, 2009, 01:01 PM
enjoi1968's Avatar
enjoi1968
Blake Pendleton
98 D1
It's only $75, why not just replace it?
It is 16 years old, so I'm putting $10 on not being good anymore.
Old November 11th, 2009, 01:07 PM
bjf's Avatar
bjf
barry f
94 ST #395
just wondering really. I wanted to learn a bit first about it. I need to do this as well.
http://www.roversnorth.com/store/p-5...-drop-arm.aspx
Old November 11th, 2009, 02:53 PM
1. It is probably fine.
2. Buy OME.
3. It does not bounce back as it is not gas charged.
4. To test, remove it and extend and compress by hand and if it is relatively difficult to do and more importantly goes smoothly both ways, it is fine.
5. Unless the ball joint is actually bad/worn, I recommend getting just the boot and replacing that on the drop are because installing the kit is a PITA.
Old November 11th, 2009, 04:12 PM
bjf's Avatar
bjf
barry f
94 ST #395
I am not sure. the boot is torn for sure and the balls moves back and forth but maybe that is normal. Where can I get just the boot?
Why is it a pain. It looks like you remove the arm and do it in the comfort of your living room. Just guessing
Old November 13th, 2009, 03:50 PM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
I am thinking about replacing my steering stabilizer too. Has any one used or tried this kind?
click here>>> Steering Damper
I wonder if the spring/shock design would improve the steering or wear-out the pump.
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old November 13th, 2009, 04:02 PM
ORover's Avatar
ORover
Fred
NAS 110s #24 and #466
That's cool! I'd like to try that one. Curious too if anyone has tried it.
Old November 13th, 2009, 04:30 PM
the upper race is Pressed in and there is not much lip to knock it out. good luck doing it in your living room unless you have a big bench vice on your coffee table...
oh, and the return to center steering shock I would just flat out avoid. If the steering doesn't return on its own then something is wrong and you would just be masking the problem.
Old November 28th, 2010, 11:44 PM
Cr4evr
Roland
1995 Defender 90 soft top
I tried the return to center steeering stabilizer on my D-90 recently. The system does not work as advertised. In fact the spring retainer cannot be tightened enough to prevent it from traveling up and down thr stabilizer. Sounded like a good idea originallly, but will settle for an OME
Old November 29th, 2010, 01:21 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
What does steering stabilizer do exactly?
My steering feels a bit sloppy and I have what can be best described as a "knot" in the steering. When doing a full right turn there is a muffled clunk at a certain point in the turn. I figured something is rubbing or something is loose and there is play in the system. Any thoughts what this could be?
Old November 29th, 2010, 02:14 AM
Bad CV? Bad ball joint?
Old November 29th, 2010, 09:44 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
It dampens (Rover calls them steering dampers) shocks to the steering when one tire hits something. It's to help keep the steering wheel from whipping around. They are not for reducing play in steering components that are worn, which I lot of people think.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 29th, 2010, 10:12 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I'm not ruling anything out. The steering may have taken a beating last time I went wheeling. It could have been there before but I started noticing shortly after getting back from two days on the trail.
If you hit rocks while sliding downhill and it forces the wheels in all sorts of directions, what part of the steering are susceptible to damage?
Old November 29th, 2010, 11:36 AM
I have the same ... can you just buy a boot?
Steering stabilizer... Death Wobble.. TDI Guy Defender Technical Discussions 13 September 15th, 2008 12:27 PM
OME Steering Stabilizer broder Defender Technical Discussions 1 January 4th, 2006 12:01 PM
steering stabilizer jimmy salmon For Sale - Parts 0 May 10th, 2005 12:44 PM
Steering Stabilizer...will it help? P1CR Defender Technical Discussions 11 November 26th, 2003 01:55 PM
