steering stabilizer - Defender Source
Old March 6th, 2009, 06:14 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
steering stabilizer
I just got an OME front steering dampener/stabilizer and I was wandering how difficult it is to install? Do I need to lift the front wheels off the ground to replace? is the old stabilizer under tension/compression if I don't get the wheels off the ground?
thanks everyone!
Old March 6th, 2009, 06:29 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Just go for it. The only difficulty is that the damper may want to turn when you are trying to undo the nuts.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old March 6th, 2009, 06:31 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
can't be as hard as breaking every bolt off trying to replace the damn gas tank cradle!
thanks!
Old March 6th, 2009, 06:54 PM
MonLand
Loic Fabro
No, that one will be a walk in the park then! ;-)
MonLand
1995 D90 NAS
1996 Discovery NAS
Old March 6th, 2009, 08:04 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I have the same OME damper installed, I dont recall that I had to jack front end off the ground to install it.
Yepper.... very easy compared to the old gas tank craddle.
Old March 6th, 2009, 09:01 PM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
i just replaced mine original with a bilstein. did not have to jack up the front. you may have to use a large screw driver to help line the holes up.
Steering stabilizer... Death Wobble.. TDI Guy Defender Technical Discussions 13 September 15th, 2008 12:27 PM
OME Steering Stabilizer broder Defender Technical Discussions 1 January 4th, 2006 12:01 PM
steering stabilizer jimmy salmon For Sale - Parts 0 May 10th, 2005 12:44 PM
Steering Stabilizer...will it help? P1CR Defender Technical Discussions 11 November 26th, 2003 01:55 PM
