Steering shaft removal - Defender Source
Old January 29th, 2013, 10:25 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Ok I know I have done this before but I have no idea how I did it. I have covered both knuckles and shaft ends with PB but the thing wont budge. Any ideas in how to get good leverage on it?
B
Old January 30th, 2013, 01:08 AM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Nope. Talking about #17 in this pic. http://c7743.r43.cf2.rackcdn.com/Ima...ew2_Phase2.jpg
Old January 30th, 2013, 01:25 AM
Do you have the box off and the bolts all the way out (not just lose)?
If so it comes apart with force.
Old January 30th, 2013, 01:40 AM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Bolts are just lose. So all the way out they will go. I dont plan on pulling the box. i am just replacing the standard shaft with straighter one so I get clearance with my headers.
Old January 30th, 2013, 02:22 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
make sure you take the bolts out of the knuckle joints ..spray it up good and try tapping the ends with a hammer to shock the splines if they don't move tap a small chisel in the split of the knuckle to relive the grip on the splines and compress each end you should be able to get it out without taking the box out
No Mall crawler here
Old January 30th, 2013, 06:18 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
X2. You have to take the bolts all the way out as they sit in a groove in the shaft.
Semper Fi!
Old January 30th, 2013, 11:24 AM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Gracias. I was about to get out the cutoff wheel and the torch. Always easier once you know what you are supposed to do.
B
Steering shaft question jayz Defender Technical Discussions 5 July 27th, 2012 08:37 AM
Inner Shaft removal for Upper Steering Column gas-man Defender Technical Discussions 6 March 16th, 2012 08:43 PM
Steering box shaft movement after tightening pitman arm nut Neil McCauley Defender Technical Discussions 18 June 10th, 2008 02:18 PM
Steering wheel removal? howellm70 Defender Technical Discussions 5 February 5th, 2004 06:14 PM
