Steering rebuild - Defender Source
Old October 18th, 2010, 05:22 PM
willr's Avatar
willr
WILL RAGSDALE
NONE
Steering rebuild
I was driving in the mountains this weekend and noticed that when I am going around turns to the left I get a left to right vibration in the steering wheel. I have a 1985 110 and I am wondering what steering components I need to replace, ball joints tie rods etc. Has anyone had a similar occurrence? And if so, then please coach me up on what needs to be replaced.
Many Thanks,
Old October 18th, 2010, 05:40 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Check that your wheel bearings are not loose.
As far as the rebuild. Ball joints and bushings are the first on the list. Easy to check.
Search around the forum and there is plenty of info.
Old October 18th, 2010, 05:42 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
take a look at your alignment too. Its a simple job.
Old October 18th, 2010, 05:47 PM
+1 Had the same thing happening, and had an alignment and balance done when I got the new rims and tires, and no more shake.
Old October 18th, 2010, 05:59 PM
bjf's Avatar
bjf
barry f
94 ST #395
I get a shake in my 90 at 55 then it goes away. Assuming that would be balancing?
Old October 18th, 2010, 06:01 PM
That went away when I got them balanced as well...so I'd assume yes. I had it from 55-70 mph (according to the speedo).
Old October 19th, 2010, 07:30 AM
Same thing here too, balancing my tires did wonders especially since they arent round
Old October 19th, 2010, 02:46 PM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
I had a "shimmy" for years in my D-90 SW from 55-60 mph. Last year I replaced the down am ball joint (rebuilt), the four ball joints and had the hubs overhauled (new gaskets and one wheel bearing). Then had a realignment done. No more shimmy. Oh yeas, the shimmy was there from new (6 miles on the clock).
rebuild
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
steering drop arm ball joint souza Defender Technical Discussions 20 February 29th, 2008 11:41 AM
steering box rebuild ('94 NAS D90) cgalpin Defender Technical Discussions 3 December 23rd, 2007 10:17 PM
