Steering question - Defender Source
Old April 10th, 2006, 10:18 PM
d901560's Avatar
d901560
Brian B
94 ST
Steering question
I did some wheeling last weekend at SCARR and when I got back on the highway to return home I noticed the steering wheel is now about 10 - 15 degrees to the right off from center when driving straight ahead. The truck drives straight when I let go of the steering wheel at highway speed and otherwise feels normal. I inspected the drag link and track rod and both appear straight. The pitman arm is not quite centered when the wheels are straight. It is slightly angled towards the left (driver's side) of the truck. I believe this to be the normal position. There are no scrapes or signs of trail damage on either part. Any ideas?
Old April 10th, 2006, 10:42 PM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
Mine is the same location and I notice no other problems I just noticed and I don't think it was from any wheeling as for I have not done any in a long time.
Old April 11th, 2006, 01:24 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
take a close look at the rear trailing arm mounting (at chasis) brackets as well as the front radius arms and look for any misplacements and bends. Sometimes you bend/offset one of these, but the truck still want to track straight and has to compensate a little, hence the wrong steering wheel locations.
Old April 11th, 2006, 08:39 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
i have the same issue and its due to the drivers trailing arm being slightly bent as well as the drag link being bent.
Jimmy Buffett
steering question - groan turning right Emerson00 Defender Technical Discussions 5 December 12th, 2009 10:57 PM
Steering box tie bar question Brim Defender Technical Discussions 2 September 29th, 2008 07:54 PM
Pitman arm to Steering box question dmarchand Defender Technical Discussions 3 September 5th, 2008 11:53 PM
Steering / differential question Emerson00 Defender Technical Discussions 6 October 31st, 2007 12:31 PM
