steering pump - Defender Source
Old February 6th, 2014, 12:26 AM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
steering pump
Ok, simple question but can't seem to find any threads. Online searches reveal 300 TDi pumps. Also, the LR workshop manual simply states "remove steering pump."
How do you remove the steering pump from a NAS 94 D90? I got the two bolts loosened that are used to adjust belt tension but steering pump isn't budging. Do I just completely remove these? Any other bolts or brackets?
Do I have to remove the pulley? (Seems like PITA, sprayed some WD40 on the nuts and sleeping on it). 3 bolts aren't budging.
Old February 6th, 2014, 09:05 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I think you're missing a bolt. Lock the pulley with a filter wrench and take it off so you can access easier.
- Charles Eames
Steering pump adj bolt size? DaveHuny Defender Technical Discussions 2 September 3rd, 2005 01:44 PM
D90 Power steering PUMP WhiteD90 Wanted 1 February 1st, 2005 12:09 PM
Vendor for Power Steering Pump Pulley wheel ? norros Defender Technical Discussions 0 January 19th, 2005 04:12 PM
3rd - Detroit Locker 4.10, Auto Trans, Steering Box, ABS Pump mudrover For Sale - Parts 2 August 9th, 2004 12:25 PM
