Steering problems when lifting the gas pedal - Defender Source
Old June 5th, 2016, 02:52 PM
Spanish Fly
Carlos Soldevila
1990 Defender 90
I own a Defender 90 1990, and when I lift the gas pedal, let's say to change gears, the vehicle steers right suddenly - and dangerously when on the highway!
Any clues?
tks
Old June 5th, 2016, 02:56 PM
Nooner's Avatar
Nooner
Ryan Noonan
1994 D90 NAS #159
Do you have truetrac installed in the front?
That can cause some momentary pull with power changes...
How is your steering dampener doing condition-wise? Do you get a lot of bumpsteer over potholes/railroad tracks?
Old June 5th, 2016, 02:57 PM
Are you engine mounts still present and attached properly? Check to make sure the hardware is tightened up snug. Sounds like a loose or broken engine mount.
Old June 5th, 2016, 03:11 PM
Steering damper is a red herring ... check the condition of everything else and damper last ... the damper just masks issues.
Old June 5th, 2016, 04:05 PM
Spanish Fly
Carlos Soldevila
1990 Defender 90
Thank you all for your answers.
I'll go to my mechanic on Monday and tell him about this discussion.
Scary experience this morning on the highway with my 6 year old!
Old June 5th, 2016, 04:07 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
I had this problem recently. It turned out to be a very loose trailing arm nut. A blown bushing would cause the same symptom.
Old June 5th, 2016, 04:20 PM
Yes sounds like rear steer to me. Check the big ball point on the rear as well as the trailing arm bushings all round.
Originally Posted by pendy
I'm here for the D's
Old June 5th, 2016, 05:11 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Definitely sounds like a bushing issue and, like Charles said, most likely in the trailing arms.
I have absolutely no idea how engine mounts could affect steering...
gas, problems
86 Defender 110 Pieces Parts Gas Tank, Clutch Pedal Box, Bench, Steering Box, Etc... 86Defend110 For Sale - Parts 14 January 16th, 2016 02:03 PM
LR Lifting Handles New in Pkg roverboy For Sale - Parts 9 April 3rd, 2007 02:14 PM
Lifting engine and transmission together?? cbass Defender Technical Discussions 5 November 7th, 2005 06:23 AM
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
Opinoins On Lifting A D-90 javelinadave Defender Technical Discussions 13 March 10th, 2004 08:50 PM
