steering problem (drifting) - Defender Source
Old August 10th, 2010, 09:15 AM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
I recently put on the RTE 2" springs, and now at highway speeds I have a slight drift from left to right. Any suggestions? Could it be my steering linkage? Tie rod ends? It isn't too bad, but it needs to be fixed.
That is why it is called a short cut. If it was easy it would just be "the way."
Old August 10th, 2010, 09:25 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Lower rear link-to-chassis bushings. They are inexpensive and easy to change, and cause the problem you describe a LOT... that is where you should start.
Old August 10th, 2010, 12:22 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
I am unclear as to what you are saying. The rear links? or the rear of the front links? I just installed new rear links from RTE with new bushings. If you are talking about the front links I will try that.
Old August 10th, 2010, 02:29 PM
crown14's Avatar
crown14
Verticalscrote
The rear link-to-chassis bushing, aka NRC7491:
http://www.roverparts.com/Parts/NRC7491.cfm
If you didn't replace these, you need to. Even ones that look good usually aren't when you take them out. When these get a little play in them the rear axle can walk around a bit, literally rear-steering the truck, especially noticeable during the transition from throttle to coasting/deceleration.
Major Problem...Power Steering Hose. kennybahr Defender Technical Discussions 9 January 5th, 2010 03:18 PM
Steering Problem jorge Defender Technical Discussions 2 September 22nd, 2006 05:52 PM
steering problem jorge Defender Technical Discussions 3 June 29th, 2005 08:12 AM
Steering problem! TwisteD90 Defender Technical Discussions 3 June 2nd, 2005 02:55 AM
