steering problem - Defender Source
Old June 28th, 2005, 10:14 PM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
steering problem
When at hwy speed ,I take my foot off the gas the 90 goes to the right. I had the tie rod ball joints,steering arm ball joint done aprox 6 months ago . Anyone have this problem and how did you resolve it?
Old June 28th, 2005, 11:22 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Here's a question.... does the whole front end move up and down a lot? The Defender does suffer from a bit of bump-steer at times, if your front springs are worn or too soft, and the front end compresses a lot when braking, that could happen.
-Hans
My oil line fix
My 100k stopped odometer fix
Old June 29th, 2005, 05:19 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Check the bushings on the rear axle. Mine are worn and I get a little rear wheel steering when I lift off the gas.
Jimmy Buffett
Old June 29th, 2005, 08:12 AM
I'm with Tyler, sounds like it may be worn bushings in the rear, didn't you just have them all replaced? Maybe something isn't tight? Thats the first and easiest thing to do, just crawl around and check that all the bushings are good and that the bolts are tight. Or maybe it's just too much mud on everything
Major Problem...Power Steering Hose. kennybahr Defender Technical Discussions 9 January 5th, 2010 03:18 PM
Steering Problem jorge Defender Technical Discussions 2 September 22nd, 2006 05:52 PM
Steering problem! TwisteD90 Defender Technical Discussions 3 June 2nd, 2005 02:55 AM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
