Steering noises - Defender Source
Old August 16th, 2016, 09:23 AM
Johan Venter
Johan
2016 Defender
Steering noises
Hallo. I experience a noise and vibration on my 2016 110, on the steering wheel. This only occurs when I turn the wheel to the left, not always at the same place in the turning circle, and worsens when friction is worse, e.g. at low (parking) speeds. This never happens when driving at normal speeds or on smooth surfaces e.g. cement floors. To date the pump on the steering, as well as the steering box have been replaced, but to no avail. LR South Africa tells me this is normal (???)
Any opinions/advice? Thank you!
Old August 16th, 2016, 09:52 AM
Loose wheel bearing, bad CV joint? No real way to diagnose across the internet. As you are in warranty, you are at the mercy of the dealer.
Old August 16th, 2016, 09:59 AM
Johan Venter
Johan
2016 Defender
? Normal
Thank you red. What bothers me is that I am told this is within normal limits for the vehicle.... That is why I wanted to know if others also have been experiencing the same.
Old August 16th, 2016, 12:13 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Revert to your basics and branch out an investigation from there.
As John explains no one here will be able to say your problem is precisely "such and such" with any accuracy.
So start by checking the front diff to make sure it is full of oil, then check the steering fluid levels, then check all the tie rod ends for tightness and for excessive play. ie defective components.
Then check all the linkages for something bent that will bind, look for the whole works to be adjusted to far one side and not the other, and so on.
If the dealer is discounting your issues, then take ownership.
Consider paying a non-dealer Land Rover specialist to identify the problem if all else fails.
RDavisinVA
Quick Steering Fix - play in the steering wheel. bossman429 Defender Technical Discussions 5 February 27th, 2012 07:37 PM
Gurgling noises sflash868 Defender Technical Discussions 12 March 21st, 2008 10:59 PM
strange noises from dash Lady_Offender Defender Technical Discussions 3 January 14th, 2008 03:12 PM
Strange Noises from below easy Defender Technical Discussions 37 June 21st, 2005 08:31 AM
Rear Spare Tyre Carrier Noises??? adibitar Defender Technical Discussions 7 May 23rd, 2004 06:49 PM
