Steering issues - Defender Source
Old August 6th, 2015, 03:13 PM
quick968's Avatar
quick968
Mikey
97 Defender 90
Steering issues
So I had to do a spendy top end repair last week after head gaskets let go and blew out the heater core. As part of the process, we took care of a few "while you're in there" type issues. One issue was the very sloppy steering traced to the steering box. Previously, the truck drove fine, tracked fine, just took 1/8 of a turn steering wheel input before getting a direction change, but nice and stable, NO tendency to Death Wobble. Tech "fixed" steering box, tightening the top adjuster Allen bolt/lock nut assy, and input shaft, so there is now zero perceptible play. This left the steering wheel cocked at 30-45deg, so he adjusted drag link to re-center. Problem is, the truck's steering is now scary responsive, "darty" would be the word. Since it's a SW with a heavy roof rack, this translates to some scary feelings at anything above 40-50 mph. Even minor steering inputs send the truck darting left or right and tipping heavily. A panic lane change would roll the truck. So I'm assuming he's some how adjusted either drag link or tie rod such that I have too much toe out? Need to measure, but what am I looking for as far as spec? Neutral? Slight toe in? Slight toe out? If so, how much?
THx
Mikey
Old August 6th, 2015, 03:45 PM
1/8" toe out. Just use a taper measurer. Might be a good idea to idea to download the workshop manual...
Tech should not have changed the toe. Would be best to check box adjustment per the manual.
Are you lifted? If so, you may have no castor and that makes things like you describe.
Old August 6th, 2015, 04:19 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
A brand new OME steering damper may help too. Don't buy the bilstein one though. It's pressurized. You'll be making involuntary left turns all day
Old August 6th, 2015, 04:23 PM
Should not need a steering damper, they are really only for off road. They mask problems. On the road, it should drive straight and stable.
Old August 6th, 2015, 05:42 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Your steering box preload may be overtightened. It should not have zero play.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old August 8th, 2015, 05:50 PM
quick968's Avatar
quick968
Mikey
97 Defender 90
Mystery solved I think. Close inspection revealed the track rod has a noticeable bend in it. Somebody was wheeling hard and it took a big hit. So much so that it's been rubbing on the guard attached to the diff for some time. So much that loosening the clamps to adjust forces removal of the diff guard to turn the rod tube itself, the bend is too large to rotate with guard in place. Toe measurement shows the bent track rod is now shortened enough to give something on the order of 5/8"-3/4" toe out, measured from inside face of wheel front and back. I'm guessing 3/4" toe out is pretty excessive given the manual calls for 0 to 2mm. That would explain the "darty" fealing. New track rod and rod ends assy ordered.
Thx Guys.
Mikey
Old August 24th, 2015, 02:29 AM
quick968's Avatar
quick968
Mikey
97 Defender 90
Well waddaya think guys? Could this explain the massive toe-out? Umm....yep. SPO musta done some fairly serious crawling over big stuff to make a hit that hard. My question is how did he NOT notice the change in steering behavior? And the records show it was serviced religiously at Land Rover Alexandria, how did they not see the massive bend in the tie rod, not to mention the raw metal scrape of the rod against the tie rod guide attached to the diff housing? At any rate, rod replaced, toe set to zero, steering back to normal.
Cheers
Mikey
ID:	127885   Click image for larger version
Old August 24th, 2015, 02:38 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Wow! Yup. That might have been the issue! Duh. What morons at LRAV. Nice work.
Old August 24th, 2015, 07:16 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Miley, any teenage boys in the house this summer?
Old August 24th, 2015, 07:18 AM
So not true.
Old August 24th, 2015, 08:10 AM
They are very easy to bend. Pretty much any light off roading and you get a bent rod.
Help me identify these two separate issues with steering and prop shafts Manimal Defender Technical Discussions 24 November 7th, 2016 06:34 PM
Steering issues ceedy Defender Technical Discussions 7 October 15th, 2014 11:49 PM
Diagnosing Power Steering Issues 61rover Defender Technical Discussions 4 April 6th, 2013 08:30 PM
Lashcap issues/valve cap issues trybul Defender Technical Discussions 6 January 9th, 2012 12:46 PM
Power steering pump install issues Hans Defender Technical Discussions 7 May 18th, 2010 03:49 PM
