Steering issues - Defender Source
Old September 2nd, 2014, 10:50 PM
ceedy's Avatar
ceedy
1989 Defender 110
Steering issues
The steering in my 89 110 (with power steering) isn't right.
After I turn right at highway speeds there is about an inch (measured on the outside of the steering wheel) of play in the steering wheel where the wheels don't move when I steer straight again. When the steering responds again, the steering wheel is noticeably askew (not by much but it isn't dead straight). After I turn left again it is centered again.
I had my power steering box replaced in December and I suspect it is the culprit but I can't explain to myself how it it could be behaving like this. It also looks like I have a small power steering fluid leak but if this is the issue then it seems like I wouldn't have this problem on only one side. I also checked for bent rods and everything looks OK at a cursory glance.
I tightened up the allen screw on top of the box in an effort to take the play out with no results. (http://www.defendersource.com/forum/...ad.php?t=36059)
I also bled the system.
Am I on the right track thinking the power steering box is faulty? Are there other things that could cause this issue?
Thanks!
Old September 2nd, 2014, 11:02 PM
what is the condition of the universal joints in the steering linkage before the box ? there should be no play there. If your box is new and there is no play in the universal joints going into the box it is likely in the drop arm pivot or your tie rod ends. Sounds pretty bad, I wouldn't drive it.
Old September 3rd, 2014, 06:50 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
I agree on the drop a ball joint. It was the culprit on my 110, easy fix. If there's any play, replace it.
Old September 3rd, 2014, 09:17 AM
make sure you center the box properly before you adjust the play. mikeslandrover did a writeup about this. The slop in the steering gets worse the further you steer from center on the box.
Old September 3rd, 2014, 01:43 PM
ceedy's Avatar
ceedy
1989 Defender 110
Is is scary to drive.
There isn't any play in the universal joints but I may try to remove the shaft to definitively test it.
I'll check the drop arm and tie rods to see what I can find there.
------ Follow up post added September 3rd, 2014 12:45 PM ------
I *think* I did this right but I could have made a mistake. If it wasn't centered properly could that explain the issue happening only on right turns?
Old September 3rd, 2014, 01:46 PM
YOU need to look and see what is loose. It could be a lot of things. The best way is to have someone wiggle the steering wheel, while you look and feel at each location through the steering and front suspension.
Old October 15th, 2014, 10:33 PM
ceedy's Avatar
ceedy
1989 Defender 110
Circling back to this thread after I got distracted with my engine swap project.
Uncle Douglas wins the prize, the problem was the drop arm pivot. I managed to get the arm off with no fuss with the help of my trusty Harbor Freight Ptiman arm puller. Once it was off I found that the pivot was very clunky.
Thanks for everyone's advice.
--Chris
Old October 15th, 2014, 11:49 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
When I replaced mine, I removed the bottom plate, drilled & tapped it & installed a zirk to keep the new one greased.
Help me identify these two separate issues with steering and prop shafts Manimal Defender Technical Discussions 24 November 7th, 2016 06:34 PM
Diagnosing Power Steering Issues 61rover Defender Technical Discussions 4 April 6th, 2013 08:30 PM
Quick Steering Fix - play in the steering wheel. bossman429 Defender Technical Discussions 5 February 27th, 2012 08:37 PM
Lashcap issues/valve cap issues trybul Defender Technical Discussions 6 January 9th, 2012 12:46 PM
Power steering pump install issues Hans Defender Technical Discussions 7 May 18th, 2010 03:49 PM
