Steering/Front Drivetrain Thud/Snap - Defender Source
Old August 22nd, 2012, 04:21 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
When I steer all the way left or right I hear a metallic thud or snap. It seems to be coming from my passenger side CV joint/wheel area. I don't hear it when turning all the way left but on the return it occurs. This sound occurs both when I'm turning all the way right almost towards the end of the travel and on the return. I've recently replaced my steering box, drop arm, and tightened both wheel bearings. I was told to remove my steering damper and see if that made the sound go away and it did not. Can anyone tell me if this sounds like a CV joint issue/failure? Thanks.
Old August 22nd, 2012, 04:26 PM
Lots of options... Was the truck standing still or driving?
Old August 22nd, 2012, 04:47 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
The car was moving. I believe the passenger front tire got hit straight on in an accident I had a month or so ago, I haven't done much driving since then. Could that have possibly damaged the CV joint?
------ Follow up post added August 22nd, 2012 03:47 PM ------
truck*
Old August 22nd, 2012, 08:27 PM
Doesn't happen when you are rolling or only when you turn the wheel to lock?
Old August 22nd, 2012, 08:42 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
When a CV starts to go bad you will usually hear a loud clicking when turning hard. Off road it is much more intense with varying degrees of destruction. If you have checked the bearings and they are good it might be time to pull the hub and look at the CV.
Land Rover 110
Old August 22nd, 2012, 11:23 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
I've got the CV joint out right now, is there anything I should look for to tell if it is bad/worn? Everything appears fine to me.
------ Follow up post added August 22nd, 2012 10:27 PM ------
No unusual sound when rolling, just a clunk or thud when turning all the way left or right. Only happens when I've turned the wheel almost to lock.
Old August 23rd, 2012, 06:49 AM
Worn CV joint will have play on its central axis. Push/pull you should feel very little slop.
Old August 23rd, 2012, 07:07 AM
If it only does it at lock and not rolling, id not be as worried about the CV's. How's are the ball joints and steering box.
Old August 23rd, 2012, 01:35 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
Just installed a newly remanufactured steering box from Meridan according to LR workshop manual instructions and a new drop/pitman arm. I've replaced every tie rod end and sway bar bushing with new ones.
Old August 23rd, 2012, 08:05 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
Got it figured out. Thanks.
Old August 23rd, 2012, 08:39 PM
What was it?
Old August 23rd, 2012, 10:03 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
Slightly loose panhard rod bolt where it mounts to the differential.
Drivetrain Failure d901560 Defender Technical Discussions 9 December 26th, 2005 11:31 PM
Griding from drivetrain when i hit the clutch? oldscratchggf Defender Technical Discussions 6 November 29th, 2005 01:59 AM
1990 Range Rover w/37" MTR's and Toy Drivetrain lwg For Sale - Vehicles 0 October 17th, 2005 03:06 PM
109 rolling chassis, drivetrain bulkhead $500 evilfij For Sale - Vehicles 1 June 20th, 2004 07:50 PM
banging in drivetrain prospector Defender Technical Discussions 8 June 14th, 2004 11:17 PM
