Steering Damper recommendations - Page 2 - Defender Source
Old April 6th, 2012, 12:47 PM
I do not believe, given that you have the proper swivel pre load, that a Bilstein damper will cause a push.
I just did this exact same job; rebuilt both swivels, new pins and bushes and bearings, new seals, new tie rod ends, and a Bilstein damper. Adjusted the cross rod so that the steering wheel is centered and the tie rod for zero toe in. The steering is dead perfect, I can drive hands off and brake hands off with no pull.
There is only one way to determine your swivel pre load. Until you come back and write that you have x number of pounds pull on a particular side you're just whistling in the wind. Once you know what your numbers are, it can be determined whether this is part of your steering issues or not.
Old April 6th, 2012, 01:27 PM
Sandt's Avatar
Sandt
Sandt Michener
1984 Ninety
True, I don't have the numbers for the pre load. All I know is that with the damper it turns, without it I can drive hands off with no pull.
I may be simplifying matters, I will still look into the pre load, but it just drives great without the damper! It would seem that that was the turning factor.
Old April 6th, 2012, 01:30 PM
Ya, if the pre load is too light, then the (wussy) force of a Bilstien might push it if you take your hands off. But if you are driving normally; that is, we hope, with at least one hand on the steering then the damper shouldn't be shoving the steering off kilter.
Old April 6th, 2012, 02:09 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
I have a bilstein damper and mine tracks straight with no issues. I understand in principal why people suggest they 'push' the steering but I agree with Bill that it shouldn't be an issue if everything is set up correctly.
Ian
Old April 7th, 2012, 12:54 AM
owen's Avatar
owen
Owen Jones
Yellow`95 D90 ST #2188
I agree that the symptoms quoted could point to steering geometry, especially since the lift has been reduced from 6inches to standard. Also check for correct toe-in, those symptoms are typical of too little, no toe-in or even some toe-out.
Take the damper off, test drive it and you will really notice if it is geometry - symptoms will be exaggerated. As mentioned already the steering should behave predictably and well with the damper removed. The damper shouldn't be used to compensate for geometry issues just save broken thumbs off-road!
And yes, best choice is OME - if you do need one.
"I think you need a little weatherstripping - right here..."
Steering Damper Big D Wanted 3 September 6th, 2007 08:02 PM
OME Steering Damper Nut Sergeant_V Defender Technical Discussions 2 September 10th, 2006 04:16 PM
Questions regarding Steering damper Mark M Defender Technical Discussions 2 November 20th, 2004 02:45 AM
little piece that steering damper mounts to near pitman arm evilfij Wanted 4 October 5th, 2004 08:55 PM
