Steering column upper support seal dimensions - Defender Source
Old October 4th, 2014, 10:55 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
So I forgot to order this seal MUC7000 in my last batch of ordering, but it looks pretty simple to to cut out of closed cell foam. (part 2 in the diagram)
The dimensions I have found for it online are 1.5cm x18cm x22cm. What I'm after now is the location of the hole for the steering column and what diameter the hole is. Same as the steering column smaller or larger? Anyone have one lying about they could measure for me?
Should I be considering anything other than closed cell foam?
I also forgot the anti-rattle strip for the steering column part #348747 (part 5 in the diagram) it sits between the clamp and the column. Is this just foam or solid rubber?
Hoping to get the steering column bolted back through my bulkhead today any help would be appreciated.
Name:	Screen Shot 2014-10-04 at 10.41.11 AM.png
ID:	104112   Click image for larger version
Name:	Screen Shot 2014-10-02 at 12.02.44 PM.jpg
Old October 7th, 2014, 01:48 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Put the closed cell foam on whole and cut the hole later.
Old October 7th, 2014, 07:36 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The hole is a good amount larger than the column and is elongated at one side so that you can get the support post through the hole.
Old October 7th, 2014, 10:21 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Hmm looking back at the disassembly photos it seems pretty close to the steering column diameter. But getting the support through might be a bit tricky.
Lower steering column, steering shaft transientmechanic Wanted 6 August 21st, 2013 07:54 AM
RRC steering column, or any steering column for that matter... RRCbass Defender Technical Discussions 0 February 26th, 2013 05:44 PM
WTB: D90-110 windscreen/frame, steering column, slam support and grill. Roving Beetle Wanted 4 February 25th, 2013 12:26 PM
Inner Shaft removal for Upper Steering Column gas-man Defender Technical Discussions 6 March 16th, 2012 08:43 PM
NAS 110 T support door seal lip surf110 Defender Technical Discussions 24 July 28th, 2008 11:58 PM
