Steering Column Ignition Assembly - Defender Source
Old September 6th, 2014, 11:40 PM
Dogpilot's Avatar
Dogpilot
James Wallace
Defender 90 1997 NAS ST
Well, troubleshooting why my Defender (97 NAS ST) was not going into low range. Turns out the transfer box has an inhibit solenoid. This is controlled by a relay, fed by the KEY IN switch in the steering column/ignition switch. Seems the 97, and I'm not sure what others has a switch that senses the key in the lock in addition to all the other features. It starts a cascade of items, which sense if the transmission is in park or neutral and the key is in to allow you to shift to low. So does anybody have any experience with this stupid thing? Oh, it also controls the annoying dong dong feature of the key in the ignition. If I jump it (it has contacts on the top center of the key/column lock ignition with assembly, all works.
Suppliers don't seem to have this model on the web.
Old September 6th, 2014, 11:48 PM
All the Rover autos (d1/RRC) of similar ages have the interlock. Well documented feature once it starts to cause trouble.
Old September 7th, 2014, 12:36 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
PM sent...
Old September 7th, 2014, 12:48 AM
Originally Posted by Bill Larson View Post
PM sent...
Dun Dun Dun......... Bill Larson to the rescue!!!!!!!
Old September 7th, 2014, 12:51 AM
Dogpilot's Avatar
Dogpilot
James Wallace
Well, monkeying with it some more. I may just try soldering it again. Seems if I check it with the multimeter at the terminals it works, but it is intermittent through the plug. Unrelated, the heater blower does not seem to get power now.
Old September 7th, 2014, 01:29 AM
Bill Larson
Bill Larson
Whatever...yo...
Old September 9th, 2014, 12:14 AM
Dogpilot's Avatar
Dogpilot
James Wallace
Well,
Re-soldering the connections made it work. But I also put an emergency override switch in as well, just in case. My heater blower turned out to be dirty contacts on the plug. Massive amount of wire checking for a simple fix.
Old September 9th, 2014, 12:30 AM
Dogpilot's Avatar
Dogpilot
James Wallace
Maybe...
Then again, dirt is kind of my business.
assembly
WTB brake pedal assembly abd steering column mud ruts Wanted 0 August 9th, 2014 11:51 AM
Steering column lock/ ignition One Ten Defender Technical Discussions 0 January 9th, 2014 02:50 AM
Lower steering column, steering shaft transientmechanic Wanted 6 August 21st, 2013 07:54 AM
Used but excellent condition, 97 auto box steering lock ignition switch assembly - Fo HeloBubba For Sale - Parts 4 April 13th, 2013 09:51 AM
RRC steering column, or any steering column for that matter... RRCbass Defender Technical Discussions 0 February 26th, 2013 05:44 PM
