Steering Column - Defender Source
Old December 11th, 2014, 05:00 PM
petminded's Avatar
petminded
David
1995 Defender 90- Yellow- Soft Top
Steering Column
Hi All!
After my master light switch replacement I went to replace the plastic housing for the steering column but don't know how it came off (I was not the one that removed it). It seams straight forward but as things are fragile I don't want to bend the plastic too much.
Do I need to take off the instrument cluster to put the cover back properly? Also should I remove the steering wheel (I would prefer not to have to)?
Thanks all!
Old December 12th, 2014, 12:26 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
No to both. It's fiddily around the stalks getting the gators to seat but I think 4 screws on the underside hold it together.
Jimmy Buffett
Old December 12th, 2014, 12:31 PM
What Tyler said but I would like to add that if it isn't installed correctly your turn signals won't work correctly. If they won't come on or won't cancel you need to re-adjust the plastic covers till they work again.
Old December 12th, 2014, 01:24 PM
petminded's Avatar
petminded
David
Thanks. Knew someone would know
Old December 12th, 2014, 01:26 PM
This place is chocked full of knowledgeable people and know-it-alls.
Old December 12th, 2014, 05:30 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Hi All! After my master light switch replacement I went to replace the plastic housing for the steering column but don't know how it came off (I was not the one that removed it). It seams straight forward but as things are fragile I don't want to bend the plastic too much. Do I need to take off the instrument cluster to put the cover back properly? Also should I remove the steering wheel (I would prefer not to have to)? Thanks all!
I gotta tell you and I know nothing but it was so much easier for me as a challenged shade tree, when I replaced the ignition switch, to remove the the entire cluster-mebbe 10 screws-to make sure I had the plastic shroud in properly, no steering wheel rubbing, etc. also a great time to replace any burnt out bulbs and do a little dustin' and clean in' in there...
Also, don't use an electric screwdriver for the shroud itself. Those nutserts are sitting in 21 year old plastic..
Attributed to Shayne...
Lower steering column, steering shaft transientmechanic Wanted 6 August 21st, 2013 07:54 AM
RRC steering column, or any steering column for that matter... RRCbass Defender Technical Discussions 0 February 26th, 2013 05:44 PM
97' D90 steering column plastic cover bolts januconn92 Wanted 0 April 8th, 2006 03:56 PM
steering column u-joint Noah Defender Technical Discussions 0 September 8th, 2004 07:04 PM
How to remove steering column? Chris Cox Defender Technical Discussions 6 October 22nd, 2003 07:24 PM
