Steering box tie bar to pan rod mounting arm bracket - Defender Source
Old June 12th, 2014, 08:45 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
It's been a few months since I disassemble the front end and i'm not certain about 1 item. The pan rod mounting arm bracket has 3 holes. The top 2 have bolts that go through the frame, the 3rd is a larger hole that the steering box tie bar attaches too. The problem is the hole in the mounting arm is 15/16", the steering box tie bar is 1/2" and there is no bushing.
I don't remember if i pressed a bushing out of the mounting arm and I can't find a part # for a bushing.
Does anyone know if there is a bushing to take up the gap?
ID:	96600   Click image for larger version
ID:	96602   Click image for larger version
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old June 12th, 2014, 08:50 PM
jafir's Avatar
jafir
Jafir Elkurd
That's that way it is. There should be a washer before you put the nut on.
Old June 12th, 2014, 09:19 PM
The hole is larger to allow for the huge tolerances in frame construction. Yes there is no bushing.
Old June 12th, 2014, 09:21 PM
lordhelemt's Avatar
lordhelemt
Paul
Bizarre...
Thanks for the input. I guess i'll clean up the hardware and assemble.
ac, bracket, mount, rack
Heavy Duty Track Rod Kit with Tie rod ends $250.00 SafariHP The Vendors Loft 0 August 30th, 2012 04:20 PM
Defender 110 Tie Rod Steering rod change tjfslaughter Defender Technical Discussions 23 December 14th, 2011 10:53 AM
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
Tie Rod/Track Rod joint removal....aarrrrghh DNinety Defender Technical Discussions 5 October 24th, 2010 01:08 PM
upper Pan Hard rod bracket TDI Guy Wanted 10 April 17th, 2006 06:27 PM
