Steering box tie bar question - Defender Source
Old September 28th, 2008, 11:55 PM
Brim
Steve
D-88 2.5L Petrol 1967/94
I am doing a build up from scratch and while I have owned a D-90 previously I am stuck on an assebly issue. Specifically, where my steering tie bar inserts through the Panhard/chassis bracket, it is a complete mismatch on sizing.
The bracket has an approximate 1" hole and the tie bar shaft is approx 1/2". See the attached photo. It almost looks like the tie bar shaft should have some kind of bushing on it, but I also heard that this is the correct assembly. So hard does the tie bar shaft stay centered in the larger hole??
"Umm, you can't get there from here, but if you go about 1/2 mile down the road..."
Old September 29th, 2008, 12:08 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
that looks right. Just a washer and nut.
Legend in My Own Mind.
Old September 29th, 2008, 07:54 PM
Brim
Steve
Thanks guys
Randy & Jeff,
Thanks for the confirmation, much appreciated.
-Steve
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Where to buy reman steering gear box? Chris Cox Defender Technical Discussions 4 February 25th, 2011 12:02 PM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
Pitman arm to Steering box question dmarchand Defender Technical Discussions 3 September 5th, 2008 11:53 PM
