Steering box shaft movement after tightening pitman arm nut - Defender Source
Old June 2nd, 2008, 08:14 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Hi thanks for looking, I got a serious steering issue on my D90 steering box. I noticed my pitman arm was loose (up and down movement), so I tightened it up. Problem is, now the truck pulls to the right when I steer straight, I have to compensate on the steering wheel to go straight. I'm assuming when I tightened up the nut, the shaft on the box turned a little too. Can I just loosen the locking nut and use an allen key to re-align the shaft or is the whole box junk? Thanks any help is appreciated.
Robert Deniro
Old June 3rd, 2008, 03:21 PM
Neil McCauley
Neil McCauley
Bueller....Bueller.....
Robert Deniro
Old June 3rd, 2008, 07:42 PM
Neil, I'm betting when it got loose it turned on the splines. What you need to do is stop the vehicle after driving straight. Slide under there and look straight up the back side of the drop arm and you'll see a notch. It should look a lot like a rifle sight and it should be lined up with a hole in the bottom of the steering box. If not, you need to pull the drop arm and get that lined up.
hth
charles
Old June 3rd, 2008, 07:51 PM
Neil McCauley
Neil McCauley
The splines looked keyed, in fact I have a steering box right on my desk and theres like a key between every 8 grooves on the shaft. Can the pitman arm grooves jump to the next spline like that? I will get underneath as soon as I get home and take a look. Thanks for the input.
Robert Deniro
Old June 3rd, 2008, 08:25 PM
Ok. I'll bite- you have a Land rover steering box on your desk ?
Old June 3rd, 2008, 08:33 PM
Neil McCauley
Neil McCauley
Yeah, its from Meridian. I bought it anyway thingking with my luck, I would have to buy one anyway. So if my problem is simple and I can fix it be readjusting the pitman arm, I can keep this new one and let them keep the core charge, guess I'll have a spare for when my 110 or other 90 box goes out, whenever that happens....
Robert Deniro
Old June 3rd, 2008, 09:40 PM
Yeah, It doesn't seem likely if keyed. Worth making sure the notch lines up with the hole to be sure though.
Old June 3rd, 2008, 09:54 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
The splines on the box outpute shaft are keyed. There is no way that it could have "jumped" over a notch. The part that confuses me is that the pitman arm came loose. I have never heard of that. Usually they cement themselves on there in an infuriating fashon. My guess (total guess) is that the pitman arm itself has loosened up. If it wore enough to come lose, it could have cocked a little while you cranked it back down. That would explain the steering wheel being bent.
If it were up to me, I would run over something large and at a fast speed with the left front tire. Don't see what could go wrong with that fix.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 3rd, 2008, 10:04 PM
Neil McCauley
Neil McCauley
Running over something at a high speed on a D90. Now that sound like a good way to make a sphincter grab the seat. The weird thing is, it was a continual problem, the pitmanarm would come lose (the pitman arm would have play fore and aft) and then I'd tighten it and it was fine, then weeks later it would become loose again, and of course I'd get down there, undo the locking tab and tighten again until one day it just wouldn't steer straight anymore. I'm at home and I just noticed that the steering box does have some weeping going on so I think I'm just going to swap out the whole thing. I really think the shaft moved along with the pitman and mabye bent something along the way when I tightened the nut. At first I used an impact wrench to tighten the nut, mabye I should of used a torque wrench.....oh well next time which is this Saturday, I will do it right. I just hope the pitman arm isn't damaged or bent. Thanks for the help.
Robert Deniro
Old June 3rd, 2008, 11:03 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
First, to get it tight, take a hammer and large punch and get it tight on the shaft and then tighten the nut--that will make sure it seats correctly.
First, adjust the steering box to take up any play--do a search--there are recent posts discussing this. For the steering being off center, you may have to readjust the steering wheel/steering box/front tires--the steering box is "self centering" but it needs to be in the center to have things tracking right. First, get the truck going straight on flat ground and, with it going straight ahead, stop the truck and don't move anything. Remove the drag link from the pitman arm. Turn the steering wheel all the way to the right. Turn it back two full revolutions to the left. This should set the steering box to straight center. Adjust the drag link (shorten/lengthen) to then line up with the correct pitman arm location without moving the steering wheel or the front tires (pointing straight ahead!) position. This should align everything. Now, see if it tracks straight. The steering wheel might not be "aligned" correctly--if it is just off a tiny bit, you can adjust this with the drag link although you will probably be just resetting it to where it was. If your steering box was out of adjustment, then the steering wheel will be off now. No way around this, remove the steering wheel and re-align it as close as possible and then dial it in by adjusting the drag link.
This is not to say that this was the problem, but it certainly will rule this out.
Old June 4th, 2008, 03:38 AM
Neil McCauley
Neil McCauley
Thank you everyone! I will try this technique on Saturday and report back with the results. If you guys were in LA, I'd throw a Rover pizza party complete with a keg of macrobrew
Robert Deniro
Old June 4th, 2008, 10:11 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I am in LA. I expect nothing less! Can't take it back now, it's on the internet forever!
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 4th, 2008, 12:05 PM
Neil McCauley
Neil McCauley
haha, where in LA are you? I'm in south pasadena, I would love to take a look at your truck and feed a fellow enthusiast, mabye you can watch me put together this 4.6 crate I've been wanting to get around.
Robert Deniro
Old June 5th, 2008, 11:18 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I'm actually in Temecula. But I work all around LA. Have been there 3 times this week. Don't get the Defender up there really, but we should go wheeling sometime, if you do.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 6th, 2008, 02:57 PM
Mark McDonough's Avatar
Mark McDonough
Mark McDonough
66' IIa, 95 D 90 300 Tdi, 94,98 D1
Steering Box Pitman
having recentley done an overhaul on my steering box, I have an idea that if you happen to use anything on the lock nut and tab washer but a large socket and tourqe wrench, you may have damaged one or more of the internal bushings that align the steering shaft and hold it tight through rotation. As someone else here mentioned, generally these things have a way of welding themselves to the splined shaft all on their own. If you have continued looseness, you may have set up a contidtion that is reacting to natuaral road vibration and loosening the nut. The end of that arm see's every nook, cranny and pebbel in the road as frequencey and or vibration. Summary is, the assembly must be tight and there is a spec in the workshop manual as to how much free play the arm (measured at the arm tip) can have before out of tolerance...dont happen to have that here at work.
You could also try some Green locktight but suggest this as a last resort to keep it together because together it will stay....
Old June 6th, 2008, 03:59 PM
Neil McCauley
Neil McCauley
Thanks Mark, I think thats probably what happened, it seems to be the only logical explanation that something moved inside the box. I'm glad I have a new one now, I will be installing it on Saturday with the alignment techniques I've learned here. Thanks everyone. Buck give me a ring the next time your in LA and have some time, I'll show you my rovers over pizza 626 354 2001. I know I'm a poser because the only off roading I've done is the green dot trails at goreman and the south end of Azusa canyon ( didn't cross the river too scared ) hehe
Robert Deniro
Old June 9th, 2008, 02:44 PM
Neil McCauley
Neil McCauley
Thanks for the advice from everyone. The box was a pig to remove and wrestle in due to its weight but I got it in there, with minimal flesh removed from my knuckles. The hardest part was removing the steering wheel as I had to drive to the hardware store to find the right bolt size for the steering wheel remover as the ones it came with were the wrong sizes. I do have a slight pull to the right but I figure I should take it in for a wheel alignment anyway, hopefully they can finish that end. Once again thanks everyone. Cheers!
Robert Deniro
Old June 10th, 2008, 12:18 PM
Mark McDonough
Mark McDonough
Steer'in straight
Hi Neil,
Good to see you managed to come through that fix with little torn flesh. Seems like every job with these things if it's under the truck, your in for giving up a little.
Maybe thats where the English made that expresion famous; a pound of flesh!
I always wonder why people start talking about using big hammers for repair work on these rigs. They are trucks and all but robustly built they are not. Too many seals, bushings, shims and gaskets all with pretty tight tolerances for everything to work right. Having worked on this that and the other type machinery over the years these rigs seem to be classic for needing this that or the other special persuaion tool but a hammer and crow bar only seems to add to the repair work.
Anyway, I'm sure you'll heal up before your next repair!! Good Luck!
Mark
Old June 10th, 2008, 02:18 PM
Neil McCauley
Neil McCauley
Thanks Mark, your right on that call. More importantly, I'd rather lose flesh over a rover than anything else, it just makes the pain/scars/scratches seem like it was totally worth it and lately I've been proud of showin folks my rover battle scars. Now to get the taste of power steering fluid out of my mouth.
Robert Deniro
ht
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
Pitman arm to Steering box question dmarchand Defender Technical Discussions 3 September 5th, 2008 11:53 PM
Need new drag link & pitman arm !? Rover- Girl Defender Technical Discussions 4 March 23rd, 2006 06:33 PM
little piece that steering damper mounts to near pitman arm evilfij Wanted 4 October 5th, 2004 08:55 PM
