Steering Box Rebuild - Defender Source
Old July 17th, 2011, 07:17 PM
punter
1966 Series IIA
I picked up a complete seal kit and pulled my steering box (Atwest) to rebuild it... I've got the manual with all the directions and I can't get past step one.
I cannot even get the drop arm off this thing. I've got it soaking in penetrating oil right now, but it doesn't look corroded (in fact the box doesn't even look that old). I will admit that I am just trying to use a standard 2-jaw gear/pully puller. From what I can see once the nut and washer are off, there is nothing holding the drop arm on except for friction. Am I missing something? Is it that this puller simply isn't sufficient? Anyone have any tricks for this?
Step two doesn't appear as though it's going to be any easier. There is a lock ring that I'm supposed to spin/rotate until the end is about .5" away from a hole that is drilled through the housing. Once in position, I can use a punch to push the lock ring out enough that I can get a screwdriver behind it and pry it out. I can't get the ring to budge though (in order to spin it into position). Tried penetrating oil and It's soaking right now as well, but it isn't corroded either. Any tips/tricks/hints?
Old July 17th, 2011, 07:40 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Try some heat in addition to the oil. Might need a three-jaw puller. Make sure you are "pushing" on the rod and not "pulling", ie the correct direction.
I'm sure you know you can get a "rebuilt" unit from Meridian (has improved bushing design). Also highly recommend switching to Disco pitman arm which allows you to use a "normal" tie rod end that is very easy to remove.
Old July 18th, 2011, 01:00 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
With all the time and effort you'll spend in rebuilding...it's cheaper to just replace. Normally the box's leak due to something inside worn out (gears,bushings,ect). The seal kits don't work that often unless you are meticulous about it and check for anything else that is worn out besides seals and have the correct tools and know-how. Seems simple on paper. Good luck
Old July 18th, 2011, 01:58 PM
GYM's Avatar
GYM
Gary
97 SW
I had this problem too. Finally got so frustrated I took the box to a shop that did steering box repairs and paid them a few bucks to pull the dumb arm for me. Took him about 10 seconds. Consider this option. Your lower blood pressure reading will thank you.
rebuild
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
More Steering Box Questions kzack Defender Technical Discussions 6 May 5th, 2011 12:51 PM
Where to buy reman steering gear box? Chris Cox Defender Technical Discussions 4 February 25th, 2011 12:02 PM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
