Steering box question - Defender Source
Old August 18th, 2012, 01:42 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
In the continuing search to find the problem with my steering I have come across the next issue. At the connection between the steering box and the shaft from the steering wheel there is some play. It's not much but when the truck is off and you wiggle the steering wheel back and forth the shaft coming out of the steering box turns about an eighth to a quarter turn each way. I tightened the adjustment screw a little bit but it didn't seem to affect it. How much can you tighten the adjuster? I only went about a half a turn. Should I keep tightening it or is my box shot? What is the best solution here, rebuild or replace?
Thanks, Jason
Old August 19th, 2012, 08:35 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Have you checked the splines on the box and the shaft? You can get a replacement re-manufactured box, with exchange, for less than $400.00 these days.
Land Rover 110
Old August 19th, 2012, 10:12 AM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
Jason-
I got a used steering box for my row rhd '84 d-90 from one of the guys on this site. I had him mail it to meridian for rebuilding. After I get it back and have it installed, my old box will be available for sale if you want it. I went this route instead of removing my current box and mailing it out for rebuilding because I use my truck every day and I didn't want to be without the defender while waiting for rebuild, shipping, etc. In fact, the guy I bought the box from did the same thing. If it helps, Let me know if you need the box. Its a 4 bolt box. I paid $100 plus $60 shipping to meridian and would be happy to do the same... not looking to turn a profit or anything... Just passing on the same cost I paid. Anyway, good luck.
Old August 19th, 2012, 11:31 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Thanks Mike, I may take you up on the old box. I am going to take it to West coast British this week, I hope and see if he may have one that he can fix and exchange and what he will charge. Has anyone rebuilt one themselves, is it that difficult? I have looked at the blow up and there aren't that many parts inside there. I think I have seen rebuild kits for sale.
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Where to buy reman steering gear box? Chris Cox Defender Technical Discussions 4 February 25th, 2011 12:02 PM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
Pitman arm to Steering box question dmarchand Defender Technical Discussions 3 September 5th, 2008 11:53 PM
