Steering box noise - Defender Source
Old August 15th, 2016, 10:50 AM
Johan Venter
Johan
2016 Defender
Steering box noise
Hallo. I am from Namibia. Recently bought the very last 110 Station Wagon sold here (Feb 2016) I changed the tires to all terrains, but since experience a noise and vibration coming from the steering wheel. This happens only when the wheel is turned to the left, not always in the same spot on the steering circle, and is associated with a vibration felt on the steering wheel. This only happens when friction is relatively high, e.g. at parking speeds. It dissappears when steering on a slippery surface.
Is this normal, and how to fix it? (To date the hydraulic pump on the steering as well as the steering box have been replaced, without effect. The dealership now wants to replace one of the pipes carrying hydraulic fluid.)
Thank you!!
86 Defender 110 Pieces Parts Gas Tank, Clutch Pedal Box, Bench, Steering Box, Etc... 86Defend110 For Sale - Parts 14 January 16th, 2016 02:03 PM
Ticking noise from steering columb or dash... Drjeggle Defender Technical Discussions 3 June 19th, 2013 06:28 AM
Steering box noise jayz Defender Technical Discussions 1 July 22nd, 2012 04:19 PM
White noise type sound from steering wheel aosias Defender Technical Discussions 1 January 31st, 2009 01:47 AM
power steering pump noise cgalpin Defender Technical Discussions 8 October 27th, 2008 06:11 PM
